It is currently Mar Tue 26, 2019 3:15 am
 Post subject: SCR-274-N command set and T-17 microphone woes
PostPosted: Feb Tue 05, 2019 3:00 am
I have a SCR-274-N command setup with a BC-456 modulator, and T-17 mic. Of course the T-17 is dead well almost dead anyway I've heard that an electret element can be swapped out in place of the stock carbon mic has anyone tried this, and which element did you use?
 Post subject: Re: SCR-274-N command set and T-17 microphone woes
PostPosted: Feb Tue 05, 2019 4:00 pm
Hello Dave,
The T-1 handset microphone element from an old telephone is recommend here for use with RM-12!
http://amfone.net/Amforum/index.php?top ... #msg269223
Not sure if this would suit your setup... :shock:
NOS: https://www.ebay.com/itm/153331168277
Lots more on ebay.
:) Greg.
oh... here is a bit of major surgery to make a T-5 fit.
http://k4che.com/T-17/T-17.htm
Wear eye-protection. Lol
PostPosted: Feb Wed 06, 2019 12:37 am
egg wrote:
Hello Dave,
Lots more on ebay.
:) Greg.
I was thinking of using a microphone element from an old telephone handset wasn't sure what vintage telephone handset I need to look for 60's or 70's?
PostPosted: Feb Wed 06, 2019 2:42 pm
Nice setup Dave! Sometimes the carbon particles in the mic
element get packed and a good whack will loosen them up.
Nothing to loose. Is the mic getting the right bias?
Steve
PostPosted: Feb Wed 06, 2019 7:07 pm
Used a couple of T-17 on my TBS-50 a few years back. Worked fine as is.
https://www.flickr.com/photos/42774321@N08/3939067236/
Terry N3GTE
PostPosted: Feb Wed 06, 2019 8:33 pm
I agree with the "couple of sharp raps" on the table.
Decades ago the T-17 was very popular in private aviation, and they would slowly become unusable, so I simply told the customers to give'em a couple raps on the wood part of the counter here, and see if that fixes your problem, but if not, I have these shiny new electrovoice carbon mics for 39.95.
Fixed quite a few and sold quite a few, business was good, and happy customers to boot, regardless of the outcome. That eventually meant, even more repeat business.
PostPosted: Feb Wed 06, 2019 9:20 pm
Hi Dave
This is what I currently use:
https://www.mcveyelectronics.com/milita ... -prototype
This just showed on the AMForum:
http://amfone.net/Amforum/index.php?topic=44604.0
73 Mark K3MSB
www.k3msb.com
PostPosted: Feb Thu 07, 2019 8:27 pm
There seems to be two schools of thought on what happened to the T-17 after the war. The most common belief is that these mikes more or less failed after a few years as the carbon granules packed up and humidity got inside. It's probably safe to say that every single T-17 left by now has weak or almost no output. I have T-17's from estates that had already been modified with telephone parts back in the early 50's, using those big bullet-nosed E-series cartridges from 1930's desk phones of the 200 and 100 model ranges.
The other belief is that these were mostly used in aircraft which were very noisy and shouting into the mic was expected, and they were not supposed to have any more output than they do. I don't buy this because these were also used in ground equipment and if you had to shout when using it in that situation, you made yourself a target,
Also, the other microphones such as the RS-38 do not exhibit this problem and usually still work just fine.
For our purposes, whatever the reason, the T-17 will have to be modified with an electret or a more modern carbon cartridge, such as out of a 300 or 500 series desk phone handset. I don't know if anyone has figured out a way to reactivate the existing T-17 insert. I tried heat and got nowhere. Even rapping on it eventually quit giving results.
Some people have drilled a lot more holes in the cap, but I don't think this really helped and certainly makes the mike look ugly.
WB6NVH
http://www.wb6nvh.com
PostPosted: Feb Fri 08, 2019 2:58 am
Here's the output of the carbon element in my T-17:
Here's the output with the McVey Electronics replacement:
The McVey replacement in my T-17:
And the finished T-17:
73 Mark K3MSB
www.k3msb.com
Post New Topic Post Reply  [ 9 posts ]  Moderator: Sandy
Users browsing this forum: Norm Johnson and 3 guests
