It is currently Sep Fri 25, 2020 4:18 am
 Post subject: Telefunken the rainbow
PostPosted: Apr Sun 21, 2019 6:31 pm
restoration start: E127Kw5
shortwave BA, 8 tubes, mw up to 30MHz, BFO.
it is a light weigt relative from my E104Kw4/7
around 80 pounds.
greetings
Martin
 Post subject: Re: Telefunken the rainbow
PostPosted: Apr Sun 21, 2019 6:33 pm
Not exactly a pocket radio. Like to see the insides sometime, sure is interesting.
PostPosted: Apr Sun 21, 2019 6:41 pm
I will post a restoration report,
this will be some work. Re coloring the scaling plate with red and orange, how to?
http://www.seefunknetz.de/e127.htm
here are some pictures to see what is comming. The site shows a /Kw4 , zivil version.
/Kw5 is the MIL version, with plugs on the front, upside. MIL Version in grey is the german navy, so we have a true boatanchor 8)
PostPosted: Jun Wed 12, 2019 4:24 pm
that E127/Kw5 is the radio version made for the state and military.
The differents to the civil version /Kw4 is:
All Plugs are connected to the front plate,
and there was a optional protection mesh (very ugly!)
The radio is a single conversion super using 8 Tubes, the IF is 525 kHz
The IF stage have a crystal filter and allow the selection of 4 bandwiths up to 6kHz.
There are no electrolytics, the radio is complete build with metal paper C and SQ tubes.
The gear train have a pull, 20:1 fine, push 1:1 fast. BFO is there, also a lf filter .
It have a little loudspeaker in the front and a holding for a small document.
The weight is 44kg.
The Telefunken Family :D
E108/Lw4 (left side down) is the large size VLF+LF Radio.
E104/Kw4/7 (right side down) is the large size SW Radio.
E127/Kw5 (right side up) is the mid size SW Radio, the rainbow. Internal Tubes Tester: no.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Sandy
Users browsing this forum: Adam Vaughn, Chris Props and 15 guests
