It is currently Oct Mon 14, 2019 4:23 am
 Post subject: Harris "Pacer Bounce" 1KW Amplifier
PostPosted: Jun Sat 08, 2019 2:59 am
All, OK My power supply arrived for my Matching 1KW amp.. Its NOS Perfect condition..
Any Military Experts Out There?
Question..
1. Is anyone running this combination?
2. The Power supply connector I think its a MS3106-28-16S Is that correct? Does anyone have a source for that connector..
Need to make up a cable from Power Supply to AMP..
3. Can the power supply be tested without the AMP and Radio.. To make sure its working before Hookup..
IF so How?
Skip
 Post subject: Re: Harris "Pacer Bounce" 1KW Amplifier
PostPosted: Jun Sat 08, 2019 3:00 pm
Hi Skip,
Your MS3106 is a MIL-C-5015 series plug (the outside metal housing).
The mating connector would be an MS3100, MS3101, or MS3102.
The 3100 and 3102 are chassis-mounted housings.
The 3101 is a cable-mounted housing, and requires a backshell ordered separately.
The mating connector insert (male) would be a 28-16P.
You must choose the desired housing (straight, right-angle, etc).
Mouser, Newark, and Allied carry them. I think Digi-Key does also.
http://www.Mouser.com
http://www.Digikey.com
http://www.Newark.com
http://www.Alliedelec.com
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
Post New Topic Post Reply  [ 2 posts ]  Moderator: Sandy
Users browsing this forum: Lar H and 3 guests
