It is currently Apr Wed 08, 2020 2:39 am
 Post subject: Ten Tec 555 RF First Stage Amplifier ( Component Value )
PostPosted: Feb Sat 22, 2020 9:16 pm
Hello.
Ten Tec Scout 555 Amateur Radio.
Curious, if you could help to determine the value of two Inductors in a RF ( 1.8 MHz - 30 MHz ) Transistor Power Amplifier ( 1st Stage ) Push - Pull Amp Circuit. ( ? )
The manufacturer failed to print two Inductor values on the Schematic of the components in the (attached) picture - Schematic.
Components L3 and L11 - what would be reasonable values of these ? ? ?
Thank you for any help.
cferry1
 Post subject: Re: Ten Tec 555 RF First Stage Amplifier ( Component Value )
PostPosted: Feb Sat 22, 2020 11:14 pm
I would suspect they are 1uH. Looks like they’re there to block the RF, just like L9 and L11.
-Scott
PostPosted: Feb Sat 22, 2020 11:41 pm
Schematic has two inductors labeled L11 but, as indicated in the previous post, 1uH is a good guess.
PostPosted: Feb Sun 23, 2020 1:13 am
Yeah, my bad. I meant to type L10.
PostPosted: Mar Wed 11, 2020 4:00 pm
Ten Tec used a lot of miniature radial lead RF chokes for those applications. I'd say they are 100-uH radial lead chokes based on the Paragon and Omni series rigs. Those are for decoupling, and not part of a resonant circuit.
PostPosted: Mar Sat 28, 2020 8:30 pm
Thank You for All your suggestions.
I believe you / we are on target or at least close !
Post New Topic Post Reply  [ 6 posts ]  Moderator: Sandy
Users browsing this forum: rocketeer and 7 guests
