It is currently May Sun 24, 2020 11:04 pm
 Post subject: Alinco DR610T
PostPosted: Mar Thu 26, 2020 11:43 pm
VHF/UHF 50/10/5 watt. Has RF power but no modulation on any power setting on any band.
Microphone appears to be good. Any ideas from anyone. I contacted Alinco, but no help there.
"No Humming" - sign in a Capacitor factory.
 Post subject: Re: Alinco DR610T
PostPosted: Mar Fri 27, 2020 1:19 am
The service manual is available for free on Alinco’s web site. On the CPU board, IC-504 is the mic amp. It’s two cascaded op amps. The first amps input is pin 6, first amps output is pin 7, second amps input is pin 3, second stage output is pin1. VR-503 is the level adjust and pin 8 on the CPU board connector is the mic out to the UHF and VHF boards.
PostPosted: Mar Fri 27, 2020 3:41 am
Found the problem.... short harness plug for the "head" unit pulled away from a socket. Both plugs removed, cleaned and inserted FIRMLY.
Unit now works.
Thanks for the schematic tip, Scott.
Post New Topic Post Reply  [ 3 posts ]  Moderator: Sandy
Users browsing this forum: SteveH and 8 guests
