It is currently May Sun 24, 2020 10:42 pm
 Post subject: HT-32 VOX
PostPosted: Mar Sun 22, 2020 10:25 pm
I have a Hallicrafters HT-32. Finally have it up and running bu the VOX will key the xmit but it will not unlatch. VOX adjustment has no effect. Any ideas?
 Post subject: Re: HT-32 VOX
PostPosted: Mar Mon 23, 2020 9:22 am
Greetings to wb3cyb and the Forum:
If the VOX Sensitivity control has no effect, try replacing the VOX relay tube (it looks like V17 on the BAMA schematic, but it is so blurry I can't be sure). If that has no effect, check the value of the VOX delay pot R49A and the value of R48.
Jim T.
KB6GM
PostPosted: Mar Tue 24, 2020 12:30 am
Thanks. I'll give it a look this weekend.
PostPosted: Mar Thu 26, 2020 10:48 pm
Missed a ground when re cap was done. VOX works fine now. Thanks.
Next problem....meter works briefly then drops out....
Post New Topic Post Reply  [ 4 posts ]  Moderator: Sandy
