It is currently Feb Tue 18, 2020 7:59 pm
Post New Topic Post Reply  [ 179 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
 Post subject: Re: Westinghouse model 801 grandfather clock radio.
PostPosted: Sep Wed 04, 2019 12:06 pm
Another picture
PostPosted: Sep Sun 08, 2019 11:08 am
With the cabinet all done and I guess ok job. I am now looking at electrolytic can that has three wires and one I believe to be ground so is that correct? The other two I assume to be two 8 mfd caps but schematic is still showing a 2 mfd also.
PostPosted: Sep Sun 08, 2019 4:28 pm
Right now the radio cap block is has follows.
- brown wire I think cut and not used
-red wire to det coil
-blk wire to ground lug on chassis
-also have a 8 mfd cap with one end on same point on det coil has red wire and other end on pin 5 of speaker plug
PostPosted: Sep Sun 08, 2019 9:52 pm
One thing I do not understand is the exterior 8mfd electrolytic has two wires only that I believe to be attached to two positive points for the two electrolytics det coil and pin 5 of speaker plug
PostPosted: Sep Mon 09, 2019 12:52 am
I now have the chassis put aside for now. Unless someone can shed some light on correct placement of electrolytics.
PostPosted: Sep Mon 09, 2019 10:09 pm
Well i guess i will send the chassis off somewhere to be repaired.
PostPosted: Sep Tue 10, 2019 8:36 am
Guess I should ask one more question should I expect any more help or have I been put on a list for not getting any more help thanks
PostPosted: Sep Tue 10, 2019 11:23 am
Connect the electrolytics in accord with the schematic. Physically, they should be in the same general location as the originals. Remind me which schematic you are using, and I can be more specific.
I advise you not to post statements like this. You get pretty consistent help here. Noone here gets paid, and sometimes you just have to wait for answers.
"patience is a virtue"
PostPosted: Sep Tue 10, 2019 12:43 pm
Everyone here encounters problem projects from time to time that may seem unsolvable. When it happens to me, I stare at the radio and stare at available drawings till the (dim) light bulb (in my head) comes on.
Walking away from the problems from time to time helps the process.
We call this process "Thinking about it" :wink:
Perseverance is another helpful virtue.
Paul
...... how hard can it be?
PostPosted: Sep Tue 10, 2019 11:25 pm
like the pacific tv one has it has 16 pages and very detailed but this is why I am questioning the electrolytics.
PostPosted: Sep Wed 11, 2019 10:17 am
There are 2 electrolytic caps shown on the schematic: 10uF and 8uF. There is a note that the 10uF cap is actually an 8 and 2 in parallel. This is illustrated in the wiring diagram in figure 10. (Note an error in Figure 10---the filter cap assembly is labelled "by pass condenser")
Figure 6 shows the filter assembly near the center of the chassis.
The new electrolytics can be installed under the chassis, or you can restuff the original can--if they will fit. If you put them under the chassis, they should be as close as possible to the original location. The values can be somewhat larger than 10 and 8, but I would not make the first filter larger than 20.
You only need 2 filters---there is no reason to duplicate the use of 8 and 2 in parallel to get the 10 shown on the schematic.
PostPosted: Sep Wed 11, 2019 10:30 am
So you are talking about brown and blue wire in figure 10 page 14
PostPosted: Sep Wed 11, 2019 10:36 am
correct
PostPosted: Sep Wed 11, 2019 11:08 am
So does the one electrolytic connect the positive end to both these points?
PostPosted: Sep Wed 11, 2019 11:25 am
The + end of both caps goes to the cathode of the rectifier (The B+ source)
The negative of the first filter goes to the HV center-tap, and the negative of the second filter goes to the opposite end of the field coil.
Always use this rule:
the most positive point in the DC circuit is the rectifier cathode
the most negative point is the HV center-tap
PostPosted: Sep Wed 11, 2019 7:48 pm
So does it matter if it is pin 1 or pin 4 for positive connection.
PostPosted: Sep Wed 11, 2019 8:21 pm
no--the entire filament is the cathode
PostPosted: Sep Wed 11, 2019 8:29 pm
Not sure what you mean.
PostPosted: Sep Wed 11, 2019 9:52 pm
The filament is the cathode.**
The DC voltage in a rectifier comes from the cathode.
**More precisely, the tube has a "directly-heated cathode". Not all rectifiers have this.
PostPosted: Sep Wed 11, 2019 10:22 pm
So the connection point on det coil is cathode.
The lug attached to chassis is hv center tap.
The pin 5 of speaker plug is other side of field coil.
Post New Topic Post Reply  [ 179 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
Users browsing this forum: ArnoldJRimmer, calman44, devilsmist, Ed Engelken, lorenz200w, rck46 and 23 guests
