It is currently May Tue 26, 2020 7:01 pm
 Post subject: PHILCO 46-1226 cant tune on high end
PostPosted: Dec Mon 02, 2019 2:45 pm
hello all....I did a full recap on a Philco 46-1226 and tried all the tuning tricks and can NOT get any station above 800 on the dial....any suggestions???
 Post subject: Re: PHILCO 46-1226 cant tune on high end
PostPosted: Dec Mon 02, 2019 6:30 pm
Can you help us with a link to the schematic you are using?
And, what test equipment can you use to work on this?
Is there more you might tell us about how the radio is working now? Does it work well below 800, for instance?
With more information, we might provide better help. Otherwise, the speculation can get pretty interesting, but may not do much for your specific situation.
Pending more info, I'll speculate that it would be good to listen for the Philco's local oscillator with a second radio. Does the LO quit as you tune above 800 on the dial?
Ted
PostPosted: Dec Mon 02, 2019 6:54 pm
An eight page Philco Troubleshooting service manual for model 46-1226 can be found at Tom Bavis' website, in DjVu format.
https://tinyurl.com/tom-bavis
I use this DjVu reader (safe download from sourceforge.net) works great.
http://antiqueradios.com/forums/viewtop ... 9#p2746819
:) Greg.
If you are using a Windows computer, here is a direct link to the DjVu reader .exe file.
https://sourceforge.net/projects/djvu/f ... rror=netix
Save it to your desktop, open it and follow the installation instructions.
PostPosted: Dec Mon 02, 2019 8:08 pm
the radio does work well below 800 anything above that its dead.....
PostPosted: Dec Tue 03, 2019 6:25 am
If you have a signal generator, go to section 4 in the service instructions and do the suggested tests. If not, try replacing the 7F8 Converter tube. Does it pick up anything on Short Wave?
PostPosted: Dec Thu 12, 2019 7:26 pm
NADA...replaced 7f8 tube and still dead above 800
PostPosted: Dec Fri 13, 2019 7:24 am
So, did you try the second radio test?
And do you have any functional test equipment that you can use?
Is the schematic linked above the same one you are using?
Ted
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: dallastube, Majestic-12 [Bot], midwestradios, SHenion, tym and 4 guests
