It is currently Jan Mon 20, 2020 9:31 am
Post New Topic Post Reply  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: General Time Corp. D170B clock bulb out
PostPosted: Jan Sat 04, 2020 1:23 am
You may need to clean off the epoxy with a scalpel and consider a pin or staples, in conjunction with industrial super glue.
A drill of 1mm or less may be appropriate.
Marc
PostPosted: Jan Sat 04, 2020 1:43 am
Marc
I haven't glued the broken part on yet, just that support wire. Pinning is a good idea except piece is too thin to do that to. I have some JB weld epoxy I am test bonding two pieces of plastic to see how it bonds.
"It's amazing what you can accomplish when you throw safety out the window", Brent Butt
PostPosted: Jan Sat 04, 2020 1:50 am
Have you considered getting someone to print a new one?
Off to deal with bushfire issues.
Marc
PostPosted: Jan Sat 04, 2020 1:57 am
Lash it with some fine wire or brace/bridge it with a small piece cut from a Coca-Cola can or feeler gauge.
"Key" aluminum with sandpaper and use a good quality glue.
These are German (industry) products - readily available in the UK
No doubt someone will recommend a stateside product. lol
Hey Marc... stay safe.
PostPosted: Jan Sat 04, 2020 4:01 am
Hardware stores in the US carry two-part plastic bonding cements, usually next to the JB-Weld. Actually, I think JB-Weld have one of these.
WM & auto parts stores also carry this stuff.
Try a tiny bit to see how it works with your particular type of plastic.
Ted
PostPosted: Jan Sat 04, 2020 4:21 am
I’ve heard that superglue can be mixed with baking soda to increase its strength and fill cracks. I need to try this myself soon to see if it actually works.
-EB
I’m learning to be a leading-edge designer of trailing-edge technology.
PostPosted: Jan Tue 14, 2020 9:50 pm
I actually got the clock back together and it works! I ended up using ABS plastic pipe cement to do repairs on the plastic, worked very good. A heck of a lot of work for something of no real value... :shock:
Post New Topic Post Reply  [ 27 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1, 2
