It is currently Nov Sun 29, 2020 3:24 pm
 Post subject: escutcheon/faceplate removal help - PB/Teledyne console
PostPosted: Oct Thu 29, 2020 3:04 pm
having trouble removing this faceplate to access the screws holding the chassis in
something towards the bottom is still holding it on....and i can't seem to locate it.
any advice on how to move forward would be welcome
 Post subject: Re: escutcheon/faceplate removal help - PB/Teledyne console
PostPosted: Oct Thu 29, 2020 3:27 pm
Use a flat steel tool like a putty knife and see if it's possible to gently pry up and remove the two trim strips flanking the control panel. It appears to me that they cover retainer bolts that hold the control panel to the wood surround, two bolts per side.
Don't forget to unplug the RCA connectors.
PostPosted: Oct Thu 29, 2020 3:47 pm
it's all 1 solid piece, the 2 trim strips on the side don't appear to come off separately
thanks, that's an older photo. i have since removed the RCA connectors
PostPosted: Oct Thu 29, 2020 4:52 pm
Surely if you have a tape measure you can locate the countersink head of the machine screw that attaches to these...
Heat the fluted side strips as mentioned with a hairdryer, protect the dial-glass with a piece of cardboard... and use a sharp wallpaper or putty knife - - don't burn anything. lol
PostPosted: Oct Thu 29, 2020 4:56 pm
lol... you will need an old fashioned (thin-wall) box-wrench to get at these, or grind down a socket!
PostPosted: Oct Thu 29, 2020 5:00 pm
Refer to the marked up photo to find the location of the retainer bolts. There would be two more on the other side, out of the photo view. These have to come out in order to remove the assembly.
PostPosted: Oct Thu 29, 2020 5:14 pm
those are already loose and have been taken out
PostPosted: Oct Thu 29, 2020 8:13 pm
If the sides are solid then the whole face plate must pry off.
PostPosted: Oct Thu 29, 2020 10:23 pm
Possible that the faceplate was inadvertently glued in place courtesy of a spilled sugary soft drink sometime in the prehistoric past.
PostPosted: Oct Thu 29, 2020 10:44 pm
mystery solved, when i heated the faceplate with a hair dryer the Packard Bell badge at the bottom came loose and the last nut was under that little nametag.
thanks for your help! it's been removed for a recap & cleaning
PostPosted: Oct Fri 30, 2020 12:42 am
I knew there was a reason why the name "Packard Bell" gave me a queasy sensation in the pit of my stomach. Who hides a retainer screw under a glued-on nameplate?!
Post New Topic Post Reply  [ 11 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: Eliot Ness, lorenz200w and 20 guests
