It is currently Jan Thu 20, 2022 12:44 am
Post New Topic Post Reply  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Cutting off a "can" capacitor - pros and cons
PostPosted: Nov Thu 25, 2021 12:30 am
egg wrote:
As mentioned… I also prefer to place them under the hood... :)
Here is a four-section replacement using Axial capacitors instead of Radials. In this example, the arrow points to the negative lead of the capacitor. (note: the body's crimped end of an Axial electrolytic capacitor is positive).
That's lovely work. I wish all the radios I have worked on had that kind of unused real estate to work with.
cheers
PostPosted: Nov Thu 25, 2021 5:29 pm
â–˛ photo: AlanBienlein.
viewtopic.php?p=2966174#p2966174
That is only easy when there is sufficient space.
Author: Illustrated Practical Asbestos - hardcover, paperback & Kindle
PostPosted: Nov Thu 25, 2021 5:49 pm
Make space... :)
Ceramic (porcelain) standoffs of various lengths can be found on-line.
Stilts can also be constructed out of…
PVC Rod Grey Plastic Engineering Round Bar.
6mm→ 20mm
heck, you can even use wooden Ramin dowels if you pilot and countersink them correctly.
inner-city-bypass-airport-link-highway-interchange-brisbane-queensland-australia.jpg [ 800.13 KiB | Viewed 170 times ]
PostPosted: Nov Thu 25, 2021 6:35 pm
FStephenMasek:
I previously used the ">>" indicator arrows to point to the negative side of an axial electrolytic capacitor until one time when it was incorrect and the capacitor blew up! Now I use the metal end to indicate the negative side. I did post pictures of it here:
https://antiqueradios.com/forums/viewtopic.php?f=19&t=403969
73,
de Larry, kq6xy
Post New Topic Post Reply  [ 24 posts ]  Moderators: Norm Leal, Marcc Go to page Previous  1, 2
Users browsing this forum: amyotte, Brett_Buck, Hammer69, Majestic-12 [Bot], Tbone, WoodchuckTN and 26 guests
