It is currently Jun Thu 30, 2022 2:12 am
 Post subject: Philo 39-45 light bulb?
PostPosted: May Mon 16, 2022 5:51 pm
Philo 39-45
This is the only light bulb connected to my Philo 39-45, but I have been unable to remove it.
Push and turn didn't work, tried screwing it out, that didn't work.
It's in real tight and I don't want to break it.
Any ideas how to remove it??
 Post subject: Re: Philo 39-45 light bulb?
PostPosted: May Mon 16, 2022 6:04 pm
rbotti wrote:
Philo 39-45
Most likely the bulb is burned out. Philco used some sort of plastic and over the years the stuff is into the spring
so usually you currently have zero spring tension on the bulb and it is difficult for sure to push and twist the dead
bulb to get it out.
As to repair of the Philco Lamp Sockets. See it all here with pictures.
https://philcoradio.com/library/index.php/shop-talk/techniques/rebuilding-philco-pilot-lamps/
Years ago I found a shouldered Nylon washer that was even better than the one used in the above illustration.
I think they were something like $10.00 per thousand washers. But click that link and fix the philco bulb sockets.
New wire is best as well.
EDIT: Found the link to the nylon shouldered washers.
https://www.grainger.com/product/GRAINGER-APPROVED-0-04-in-Nylon-6-6-Shoulder-4DCD2?opr=PDPDAM
you get a package of 40 nylon shouldered nylon washers for $5.61 plus postage from Grainger
John k9uwa
http://www.JohnJeanAntiqueRadio.com
PostPosted: May Tue 17, 2022 1:19 am
Thank you for your help John, I was able to remove the bulb with out breaking it and get a good look inside the holder.
I don't see any numbers on the bulb, it appears similar to a #51, but I will have to test later.
Rick
PostPosted: May Tue 17, 2022 1:45 am
Service manual...
• https://philcoradio.com/library/downloa ... 20Book.pdf
Push button tuning, setting and operating...
Service bulletin...
• http://philcoradio.com/library/download ... %20306.pdf
The three dial-lamps, one with a resistor all have the part number 34-2210
Specifications for 34-2210 can be seen here…
• https://web.archive.org/web/20170422231 ... /lamps.htm
As I'm sure that you already know Rick, you can frost lamps with 220-grit silicon carbide sandpaper.
PostPosted: May Wed 18, 2022 3:57 am
Greg,
Thanks for all that information, I just might learn something :)
Rick
PostPosted: May Wed 18, 2022 8:23 pm
Rick
Bulb is either a #47 or a #44 the only difference between them the #44 is brighter as it consumes 1/4 amp = 250 mA of current where the #47 only consumes 150mA and is therefore not as bright. A #51 is a small totally round glass ball on the end of the bayonet base. Or another option today. https://www.pinballbulbs.com/clear44 LED replacements for the #44 and #47 bulbs. As to the "Colors" of the bulbs. Warm White is very close to a normal incandescent bulb. Where the cool white has almost a blueish white light. Advantages to the LED bulbs. They last a lot longer plus they draw about 1/3rd of the amount of current of the normal bulbs. All of the above numbers are 6.3v bulbs.
John k9uwa
Post New Topic Post Reply  [ 6 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: AuroraOldRadios, K731 Newb, mkoxsrvg513, plronbio650, VntgRads and 43 guests
