It is currently Oct Sun 02, 2022 8:51 am
 Post subject: Radiola 18 power supply issue
PostPosted: Aug Tue 09, 2022 3:55 am
I have a Radiola 18 that does not work. Measuring voltages I find I get almost nothing on terminal 8. Should be 165 VDC
Resistors R1 to R6 all ohm out good. Coil L1 ohms out OK. C1, C2 and C3 have been replaced.
What is the likely issue?
 Post subject: Re: Radiola 18 power supply issue
PostPosted: Aug Tue 09, 2022 7:26 am
Does the power transformer gets hot?
Do you get voltage at terminal 7?
Probably the tube is dead.
_________
Website: https://johnamplifiers.webs.com/apps/photos/
PostPosted: Aug Tue 09, 2022 11:15 am
did you measure the AC voltages at the transformer secondary?
PostPosted: Aug Tue 09, 2022 11:22 am
Use a VOM, not a DVM for measured voltages and resistances.
Use the VOM to measure the resistances of the "new" capacitors.
Include what reference terminal is used to measure any errant voltage.
Re-solder every joint, remake very connection to the chassis. Especially it that chassis connection is riveted even if the VOM says the connection is good.
IMHO wiring error, bad connections, open bias resistors, open chokes open HV secondary of transformer. With less than a handful of parts...
PostPosted: Aug Tue 09, 2022 11:24 am
If your getting voltage at terminal 7 and not 8, it it is likely L1 is open or a wiring issue.
Ohm between 7 and 8. You should read through choke and the resisistor or from 8 to C-2 which you should read value of choke.
http://pages.suddenlink.net/davesradios/
PostPosted: Aug Tue 09, 2022 7:07 pm
Thanks for the help. I had opened and repotted the can containing L1 and the 3 capacitors. I went by the terminals shown on the Riders schematic, but it must be shown from the top rather than the bottom, it is the reverse of what was in there!
All is good now.
PostPosted: Aug Tue 09, 2022 7:13 pm
Good to hear!
PostPosted: Aug Tue 09, 2022 9:33 pm
Good job, Mike.
PostPosted: Aug Fri 12, 2022 10:54 am
All is good now.
You are right - that diagram is deceiving.
Brian
Ennismore, Ontario, Canada
Post New Topic Post Reply  [ 9 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: No registered users and 46 guests
