It is currently Nov Sat 27, 2021 10:07 am
 Post subject: rogers majestic dial bulb on model 9r514 tube radio
PostPosted: Jan Fri 13, 2017 7:30 am
I recently acquired a rogers majestic radio and have managed to repair it. The chassis number is 9R514. I have looked at the schematic but I do not know which dial bulb this radio needs. The old rogers part number was bulb #12690. Which kind of bulb could I use as a replacement? The bulb has a bayonet base. Thanks for your help!
 Post subject: Re: rogers majestic dial bulb on model 9r514 tube radio
PostPosted: Jan Fri 13, 2017 8:30 am
Link to thread from 2004: Pilot Light for Rogers 9R514
Matt
PostPosted: Jan Fri 13, 2017 1:32 pm
Twelve years ago (thanks to Matt's spade 8) ) I was just going by what was listed on the schematic which would be 2.0 volts at 0.06 amp which would be 60 ma. You'll note that it says "On 514 and 516 only" the 9R514 chassis being 514.
Top one
http://radio.codegods.ca/sites/default/ ... /rm-63.jpg
or
http://pacifictv.ca/schematics/rogers14-50data.pdf
According to the schematic and charts below that would indicate that it would be a type 49 bayonet lamp rated at 2 volt .06 amps or 60 ma. You can also double check by comparing the color of the lamp bead of the old bulb (should be pink if you still have it and if it wasn't substituted).....
http://www.nostalgiaair.org/References/lamps/
http://www.radioremembered.org/lamps.htm
I was trying to figure out why the 49 type dial light more commonly found in battery sets with a 2V 60ma rating which seemed to be a little low in an AC set to be the "dial" light. For instance the 515 chassis has a 7 watt bulb.... After finding a photo of the 9R514 shown below with a dial red spot "on" indicator.... that would explain the reason for that value.
http://antiqueradios.com/gallery/main.p ... emId=49977
Regards
Ken
PostPosted: Jan Fri 13, 2017 7:59 pm
Thank you for the links and explanations to answer my question! Very helpful!
Post New Topic Post Reply  [ 4 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: crtkecnkl659, Google Adsense [Bot] and 35 guests
