It is currently Mar Tue 19, 2019 11:48 am
 Post subject: Someone enlighten me to using a cap for voltage dropping....
PostPosted: Jan Wed 03, 2018 9:26 pm
O.k., I read this, online of course, and have never heard of such a thing. It goes like this:
AA5 AC set which has a resistance cord. Owner wants to replace cord with a power resistor, but someone makes the suggestion to use a capacitor to drop the excess voltage because that would be better since caps do not generate heat. It was implied that a motor start capacitor would be appropriate.
I don't know everything, but I've never heard of using capacitors in place of a resistor to drop voltage in this fashion, so teach me something new.
 Post subject: Re: Someone enlighten me to using a cap for voltage dropping
PostPosted: Jan Wed 03, 2018 9:45 pm
Capacitors have reactance as AC is applied, which can be calculated based upon the frequency, and the value of capacitance.
For the purpose of dropping voltage in a filament string, reactance is just as good as resistance and as you noted, it creates no heat if the right type of capacitor is used.
PostPosted: Jan Wed 03, 2018 10:02 pm
This site explains different ways of dropping filament voltage.
https://www.vintage-radio.com/repair-re ... calcs.html
PostPosted: Jan Wed 03, 2018 10:07 pm
Thank you for that link Norm.
Talk about feeling like a dummy for not ever have used a cap specifically for the function of dropping voltage.
PostPosted: Jan Thu 04, 2018 1:32 am
Not sure what value capacitor your looking for but this link is to an 8 Mfd non polarized capacitor.
https://www.digikey.com/product-detail/en/EXH2E805HRPT/493-13831-ND/4694508
Or select this address And then select the Mfd you want and the AC voltage of 250 should narrow down to 1 or 2 available.
https://www.digikey.com/products/en/capacitors/film-capacitors/62
John k9uwa
PostPosted: Jan Thu 04, 2018 3:05 am
If a capacitor is in series with a resistave load, the voltage across the two
parts summed, will exceed the line voltage by a maximum of 41 %.
This may cause confusion is some circumstances.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Thu 04, 2018 3:10 am
Don't use a capacitor in series with an inductive load. Voltage will greatly increase.
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: jimsp, Stan the Man and 4 guests
