It is currently Jan Sat 22, 2022 6:13 am
 Post subject: Motorola model 10Y questions
PostPosted: Sep Wed 05, 2018 6:34 pm
I have been given a Motorola 10Y radio that I want to get working, I can not tell the chassis number because the sticker is half missing.
When I powered it on only the lights lite up, no sound at all. In looking at the drawings from Galvin Mfg. There are to items labeled elec cond., there is only the larger one in the chassis and a hole for the smaller one. Can any one give me information on these 2 items?
Heath Scott
 Post subject: Re: Motorola model 10Y questions
PostPosted: Sep Wed 05, 2018 8:03 pm
Is this your chassis?
image: arf member jkoebel
Double-page schematics...
https://americanradiohistory.com/hd2/ID ... e-0012.pdf ←schematic.
http://americanradiohistory.com/hd2/IDX ... e-0013.pdf
Welcome aboard... :)
You can post photos as attachments straight out of the chute. No need to wait 24Hrs.
The skinny: viewtopic.php?p=2717120#p2717120
PostPosted: Sep Wed 05, 2018 11:48 pm
Its a little different
PostPosted: Sep Thu 06, 2018 12:29 am
Ding-ding... round two... :)
Schematic + parts: http://americanradiohistory.com/hd2/IDX ... e-0014.pdf
Other pages: http://www.nostalgiaair.org/Resources/501/M0006501.htm
PostPosted: Sep Thu 06, 2018 12:53 am
Sorry I messed up on the photo.
PostPosted: Sep Thu 06, 2018 12:56 am
10Y-1 has the motor-driven station preset feature. 10Y does not have this.
PostPosted: Sep Thu 06, 2018 12:58 am
Here is another view.
PostPosted: Sep Thu 06, 2018 1:10 am
From what I have researched so far there were 2 different chassis in the 10y, a 10-1 and a 10-2. I am mainly concerned that something may be missing from this chassis.
PostPosted: Sep Thu 06, 2018 1:34 am
Show us the underside of the chassis and we will probably see the missing electrolytic capacitor. Look for something in a paper sleeve, shaped sort of like a longer flashlight battery, with wires out the ends.
It was common practice to use an axial lead part under the chassis as a replacement. All the electrolytics are probably shot, including any replacements installed long ago.
At least the guy didn't leave that old one connected.
Ted
PostPosted: Sep Thu 06, 2018 2:35 am
Model 10Y only used chassis 10-1; Model 10Y-1 used chassis 10-2. The major differences are: (1) the 10-2 supports motor-driven tuning presets (pushbutton select switch matrix; 24V secondary on the power transformer to run the reversible motor); (2) the 10-2 chassis has an AFC discriminator/local oscillator control circuit. Chassis 10-1 omits these features.
PostPosted: Sep Thu 06, 2018 6:48 pm
Here are the chassis pics.
PostPosted: Sep Thu 06, 2018 6:54 pm
You were correct Ted, the missing one was mounted underneath, I am planning on replacing all the caps. I need to also find a wave band knob. Are there any things i need to watch out for when working on this set? This is my first radio rebuild.
Heath
PostPosted: Sep Thu 06, 2018 6:56 pm
Here is 2nd chassis pic
PostPosted: Sep Thu 06, 2018 7:35 pm
Before doing anything else, it's a good idea to check the continuity of all the coils and transformer windings. RF, IF, audio, and power. If you are lucky, you can find expected DC resistance values on a schematic. Otherwise you can ask here.
You can also check the power transformer. With the tubes unplugged, and a dim bulb in series with the AC line, apply power and verify that the transformer does not draw excessive current.
At this point you can also check the transformer secondaries for reasonable voltages. Determining what's reasonable includes considering the lower primary voltage due to the dim bulb, and the lack of any load.
If this goes well, run the unloaded transformer for a half hour or so with a higher wattage bulb to get close to normal line voltage across the transformer. Verify that the transformer gets only slightly warm.
If you want, you can see what happens with all the tubes except the rectifier plugged in. Best not to power the set with the rectifier until the electrolytic capacitors have been replaced.
Ted
PostPosted: Sep Sat 08, 2018 3:04 am
Ok Ted thanks for the info. I will let you know if I cant find the resistance loads.
Heath
Post New Topic Post Reply  [ 15 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: 8bitmime, ai6vx, devilsmist, Jim Walter, kevwr and 14 guests
