It is currently Jan Wed 19, 2022 3:04 am
 Post subject: Philco 46-1203 start up
PostPosted: Jul Fri 27, 2018 5:36 pm
Just put on bench. Variac start up showed no tuning bulb (120VAC bulb) and no current draw at all got hum out of speaker. Put in new bulb which lit up. Measured B+ 83V...needs to be 200V.
Replaced C12 (.05) and C13 (.05) they were a mess. Still measured 83V B+.
Received PS caps 15uF (150V). replaced C15...it was shot. C16 right underneath was shot so I installed a .02, what was in it was a .04 ( was an original Philco) the schematic shows a .02.
Now the tuning bulb doesn't light, no B+.......help
 Post subject: Re: Philco 46-1203 start up
PostPosted: Jul Fri 27, 2018 11:18 pm
Sorry false alarm...radio wasn't getting 120VAC. It is now and we have:
50X6
160VDC. B+
90VAC. pin6 plate
50VAC. Pin1. Heater
106VAC. Pin8 Heater
Lots of hum gets louder when volume is turned up.
PostPosted: Jul Sat 28, 2018 12:15 am
An eight-page Philco troubleshooting manual (in DjVu format) for 46-1203 can be downloaded from Tom Bavis' site Audiophile.com
should you require it.
http://www.Audiophile.com/Philco.html
Welcome to the hood... :)
oh... I use this DjVu reader (safe download from sourceforge.net) works great.
viewtopic.php?p=2746819#p2746819
PostPosted: Jul Sat 28, 2018 1:33 am
Greg, thanks heading there right now.
PostPosted: Jul Sat 28, 2018 12:10 pm
Greg, do you have the dejavu app? If so can you attach a copy in .pdf format?
PostPosted: Jul Sat 28, 2018 6:03 pm
An app (application) aka Computer Program comes as an .exe (executable file), it cannot be delivered as a pdf
An executable is a file that contains a program.
Here is a direct link to DjVuLibre-3.5.27_DjView-4.10.4_Setup.exe (for a Windows PC).
https://datapacket.dl.sourceforge.net/p ... _Setup.exe
Follow the installation Wizard to install.
then... Go to Tom's site and download the service manual.
Let me know how you get on.
oh... I'm on a Mac computer.
I've just installed the above program on my old 2003 XP machine... works great... :)
PostPosted: Jul Sun 29, 2018 12:34 am
Ok...just thought I would try. I saw some executables which led me to believe the file could be turned into .pdf?
PostPosted: Jul Sun 29, 2018 1:59 pm
Had replaced C15 15uF. Left C14 since it was newer.
Read that C14 and C15 must be matched since this is a balanced voltage doubled circuit.
Replaced C14 with match to C15. C15 was a 20uF.
Turned on and
Radio tuned in a station. Yay.
Reorientated radio and radio will not tune in a radio station.
Going to remove tubes associated with radio 7C7, 7A8,787,7C6 and clean tube socket contacts?
You can hear as the tubes warm up the output background noise changes. It sounds like some of the circuitry is intermittent?
PostPosted: Jul Sun 29, 2018 2:22 pm
Looking for ways others have thought of to quickly mech polish and clean the small dia metallic female tube sockets?
PostPosted: Jul Sun 29, 2018 3:24 pm
Tobacco Pipe Cleaners.
7-Eleven... :)
Edit: If the ones you get are too large (fluffy),
run them through a cleanly drilled hole in a piece of sheet metal (soup-can).
Cleaning Vacuum Tubes Pins
Watch: http://www.youtube.com/watch?v=UHhNCr2fYoU&t=2m12s
PostPosted: Jul Sun 29, 2018 3:55 pm
You didn't say if you successfully installed the DjVu reader... :shock:
ahyhoo... here is the Philco troubleshooting manual converted to pdf and uploaded to my Dropbox.
https://www.dropbox.com/s/v1bsnzmbwfe4z ... 3.pdf?dl=1
:) Greg.
PostPosted: Jul Sun 29, 2018 5:31 pm
Greg thanks. Did not get guide will grab from dropbox.
PostPosted: Jul Mon 30, 2018 12:25 pm
Very impressed with this troubleshooting guide. Thanks
PostPosted: Jul Mon 30, 2018 8:48 pm
B+ measures 159VDC. It's supposed to be 180VD
Should I be concerned? Or move on.....
PostPosted: Aug Fri 10, 2018 11:57 am
Received balance of replacement capacitors. Planning on replacing all of the wax and paper capacitors. I have four left to replace. Will report results when completed.
PostPosted: Aug Sat 11, 2018 3:03 am
Can somebody help me size the wattage on R4 on tube 7C7. The one I removed is approx. Dia. 0.2" x 1/2" long. I put a 1/4 watt in but it heated up quickly.
PostPosted: Aug Sun 12, 2018 12:26 am
Found a 200 ohm 2W and clipped it into circuit. Still getting hot as a pistol. Has a 21V drop across it.
Decided to swap out more of the tubes. When I removed the 7C7 tube this time I gave it a shake and heard something rattling. Put in replacement tube and voila up and running. Voltage across this resistor should only be 1V.
PostPosted: Aug Sun 12, 2018 1:43 am
21v across 200 ohms works out to 2.2W, I would use at least a 5W resistor.
Vinton Roush
Fairfield, OH
PostPosted: Aug Sun 12, 2018 12:33 pm
Purchased some 1mm dial cord string. Will fab up a dial pointer and restring.
Only have 1V across R4 now with replacement 7C7 installed. Will wait for 2W old stock TRW carbon resistors to install permanently.
The phonograph motor works so will be looking at this soon.
PostPosted: Aug Mon 13, 2018 12:24 am
Fab'd up a dial pointer.
Post New Topic Post Reply  [ 21 posts ]  Moderators: Norm Leal, Marcc Go to page 1, 2  Next
Users browsing this forum: keith49vj3, lorenz200w and 32 guests
