It is currently Oct Tue 19, 2021 7:40 am
 Post subject: Mont. Ward 62-351
PostPosted: Mar Mon 11, 2019 7:01 pm
Hi I trying to determine the electrolytic cap's C8 & C9 which is neg. and positive. the existing electrolytic cap is not labeled. It has three wires coming from it, one is black going to the resistor R5 & R6 between them. The other two wires are the same color. What is confusing to me is how C8 & C9 are connected. Is the neg. side of C9 connected to pos. of C8.
http://www.nostalgiaair.org/pagesbymode ... 011469.pdf
Jim KA8ZXJ
Spring Lake MI 49456
 Post subject: Re: Mont. Ward 62-351
PostPosted: Mar Mon 11, 2019 7:19 pm
This one is indeed a bit different than what you usually see. This pair of caps has a common positive, and separate negative leads. The single wire which goes to the rectifier filament is the common positive for the two. The other end of each is the negative terminal, one going to the R5-R6 junction and the other to the transformer HV winding centertap.
Tom K6VL
PostPosted: Mar Mon 11, 2019 7:59 pm
Clearer connections can be seen here...
http://americanradiohistory.com/hd2/IDX ... e-0076.pdf
http://americanradiohistory.com/hd2/IDX ... e-0046.pdf
PostPosted: Mar Mon 11, 2019 9:13 pm
http://americanradiohistory.com/hd2/IDX ... e-0076.pdf" -="window.open(this.href);return false;
http://americanradiohistory.com/hd2/IDX ... e-0046.pdf" -="window.open(this.href);return false;
Greg, the capacitor was not labeled either, so thanks for your help. This is a new one for me.
Jim KA8ZXJ
PostPosted: Mar Mon 11, 2019 9:28 pm
Thank you Tom, I could not go by the cap because there were no designation on the cap itself.
Jim KA8ZXJ
PostPosted: Mar Tue 12, 2019 5:03 pm
Thanks guy's I have the radio working very well. Now the hard part having to get the cabinet on, the chassis comes out the bottom, having some difficulties getting it back on.
Jim KA8ZXJ
Post New Topic Post Reply  [ 6 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: No registered users and 21 guests
