It is currently Jun Sat 06, 2020 7:08 pm
Post New Topic Post Reply  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: How does a guy fix this?
PostPosted: May Wed 13, 2020 1:25 am
Picked up an old Sansui receiver, had aux input working but not am and fm. Thought that was odd and started to trace the power supply. Found the daggum selector switch was cracked across some of the traces. The knob must have took a hard hit and cracked, the shaft it slightly bent. I plan to sand off the trace coating and solder the broken traces but I want to reinforce the board. Gonna use pieces of a junk board the split but will glue stick well to these boards? Gonna glue it on the other side opposite of the traces with maybe contact cement cuz that seems to really be sticky?
"It's amazing what you can accomplish when you throw safety out the window", Brent Butt
 Post subject: Re: How does a guy fix this?
PostPosted: May Wed 13, 2020 1:31 am
Scrape off the solder mask across the break. Then use some solid wire and solder it across the trace.
Solder will fatigue when flexed so the wire is needed.
Epoxy should work to glue on a stiffener.
Scott.
PostPosted: May Wed 13, 2020 1:40 am
After the traces are bridged, clean the board with lacquer thinner or acetone. Then use epoxy. Probably just glue will work, but you might glue on a bit of phenolic or FR4 PCB material. You can put the epoxy on both sides, including over the patched traces.
Ted
PostPosted: May Wed 13, 2020 1:52 am
I would use regular JB Weld, not the 5 minute stuff and use a backup piece of something on the back side. There needs to be some thing across the crack for additional support just as the guys already said about a wire across the land pattern crack. Denis
PostPosted: May Wed 13, 2020 1:56 am
This, exactly. I have done it multiple times and it works just fine. I typically roughen up the back side of the switch wafer and the backup material a bit with the Dremel tool so the JB Weld has something to bite into. It's not coming apart if you do that.
PostPosted: May Wed 13, 2020 2:40 am
Greg,
Why do you hate PC boards?
Jay
PostPosted: May Wed 13, 2020 2:44 am
I just repaired one of those last week.
Along with the broken traces, you will need to carefully scrape the tarnish off of the contacts and rivets and solder them to the copper traces. It only takes a tiny amount of solder. You will be removing the switch again because of intermittent operation if you don't solder down the contacts.
Jay
PostPosted: May Wed 13, 2020 11:45 am
It is often possible to put reinforcing strips on its back & bolt it (2mm) to stop it bending: Glue if you wish. You can in addition drill either side of the crack into the track & make a copper wire pin like a staple that folds over on the back & that will also stop separation. That does not have to be done to every track if it can short.
Annoying rather than an irretrievable disaster.
On the comment above: The great unwashed I have some cattle stuff here that will get rid of any fauna in the hair.
Marc
PostPosted: May Wed 13, 2020 11:55 am
JnTX wrote:
Greg,
Jay
Greg's sense of humor is sometimes unique......
Be nice to him---he knows how to find service information when noone else can.
PostPosted: May Wed 13, 2020 3:08 pm
^^^^^ This. ^^^^
Same as taught in our Micro-Miniature repair course, save for good ol' DoD using a piece of pure copper foil, Wire= copper in round form, and much easier to use. :mrgreen:
Brian
PostPosted: May Wed 13, 2020 4:07 pm
JB Weld is great but somewhat conductive. Use a non-conductive epoxy.
PostPosted: May Wed 13, 2020 4:40 pm
Marc
Is that what Greg was suggesting with the staple gun?
He just forgot to mention drilling the holes before shooting the staples.
Jay
PostPosted: May Wed 13, 2020 5:19 pm
This Sansui got a set of new 100W amps. Lots easier than repairing the originals that had about 100 parts per channel.
Jay
PostPosted: May Wed 13, 2020 5:44 pm
Jay
Smart move, given the number of counterfeit 2SA1102/2SA1104/2SA1106 and their complements out there. Sanken really missed out by not extending the production of those outputs. Gone by 1994.....
What are the amp chips? One day, I'll fix an old Realistic I've got with some of the LM3886 samples I got back in college.
Brian
PostPosted: May Wed 13, 2020 7:02 pm
These boards use a TDA7293. It's one of the few chips designed for high voltage and will take up to +/-60V power. The board has 50V caps so best to use with supplies in the 30 to 45V range. The Sansui has +/-45V supplies so the boards are a good match. The boards can take AC or DC input.
Here's one supplier. Two boards for $15.
https://www.ebay.com/itm/TDA7293-85W-Au ... 3464647535
The 33V max is AC voltage input. That produces a DC level of about 45 volts on the board.
Jay
PostPosted: May Wed 13, 2020 10:19 pm
Here is the repair. :D
PostPosted: May Wed 13, 2020 10:40 pm
Looks good. Don't forget to solder those switch contacts to the copper on the board. The ones that use the rivets to connect through the board are the most likely to have intermittent connection.
Jay
PostPosted: May Wed 13, 2020 11:02 pm
Good job, T.
Looks like you are ready to roll.
Paul
...... how hard can it be?
PostPosted: May Thu 14, 2020 12:55 am
Basically what I had in mind; so good job. The idea of the bolt was so as it was not just reliant on the glue. Don't know what the black stuff is, but keeping solvent away from the new Epoxy resin, I would at a minimum, clean it off the rivets, even considering a small wire brush: Before soldering those rivets.
Marc
PostPosted: May Thu 14, 2020 1:24 am
Well I never... :shock:
I guess whoever removed my posting of the stapler has never made a clinched-staple repair of a broken conductor.
Maybe someone complained. lol
Post New Topic Post Reply  [ 26 posts ]  Moderators: Marcc, Norm Leal Go to page 1, 2  Next
Users browsing this forum: AJJ, Googergeiger, Tom Albrecht, Torino351 and 12 guests
