It is currently Aug Wed 21, 2019 5:38 am
 Post subject: IF can of Crosley 9-122W
PostPosted: May Thu 16, 2019 8:05 am
Hi All,
I just removed internal mica capacitors in the IF can of Crosley model 9-122W and replaced them with a pair of external capacitors with different values: 100pF, 150pF and 220 pF but the radio still does not work. I also try to adjust IF can's slugs (top and bottom) but no success. The radio worked before I fixed the IF can although it had lighting noise here and there.
I put another IF can adopted from a RCA radio onto the Crosley and it worked pretty well.
Does any one happen to know the correct values of these two external capacitors and also the value of built-in capacitor from pin #5 of 12BE6 to OSC secondary winding?
For reference, according to Rider's manual, IF can frequency of this radio is 455kc
O.C
 Post subject: Re: IF can of Crosley 9-122W
PostPosted: May Thu 16, 2019 8:52 am
Are you sure you haven't broken a coil wire? Easy to measure R.
When I did replacement on an Motorola 53H I made up a jig and after scrapping away the silver migration between pri and sec, actually measured the caps. They were not the same both sides !!
I'll post a couple of scans from an article I wrote and see if they are readable
Gary
PostPosted: May Thu 16, 2019 2:51 pm
Thanks Gary. I checked two coils (primary and secondary) with a meter. No broken.
Post New Topic Post Reply  [ 3 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Bob E., Majestic-12 [Bot], rebrands, wiscojim and 6 guests
