It is currently Jul Tue 23, 2019 12:26 pm
Post New Topic Post Reply  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Capacitor Value
PostPosted: Jun Fri 07, 2019 2:22 am
I need help identifying the value of these two molded capacitors. The one in the first image looks to be a .0032 mfd but unsure of the rated voltage, and the second one the first three dots are just blank. Any help?
The wiring schematic also doesn't match the radio, but know it was working before hand. So I am matching the values currently in the radio for now.
 Post subject: Re: Capacitor Value
PostPosted: Jun Fri 07, 2019 2:42 am
Tables, calculation and fourth color voltages...
http://antiqueradios.com/forums/viewtop ... 4#p2413184
and... restuffing by gary rabbitt... :)
oh... Micamold is a brand name.
Many domino capacitors were/are paper-capacitors. Do not rotate them on their axis.
PostPosted: Jun Fri 07, 2019 2:54 am
I have the tables, but like I said the bottom image, the first three dots are just blank.
PostPosted: Jun Fri 07, 2019 3:59 am
With respect, your photo is too small, dark and out of focus. I can't see the arrow.
I know what you wrote, but, what is the make and model of your radio and where/what are they connected to?
If you process your images through picresize.com - you can shoot-up an 800px wide photo to the thread.
Posting photos to a forum thread...
The skinny: viewtopic.php?p=3032571#p3032571
PostPosted: Jun Fri 07, 2019 5:28 am
First one might be .022 uF (2-2-3). If the value is actually that high, it's probably not a mica capacitor (paper inside). Second one looks like .0015 (1-5-2).
Tom K6VL
PostPosted: Jun Fri 07, 2019 2:08 pm
Well, I can take better photos when I am home later.
However I can explain it for now.
The first image the arrow is left to right, going orange-red-red.No forth dot to indicate voltage.
The second the top arrow is right to left, all blank. The second row is left to right, red-green-brown.
I am mostly confused on the blank spaces of the six dot molded cap.
The three dot one is a 0.0032mfd but I can likely assume the rated voltage 1000v since that is highest I saw in the radio, but wanted to make sure before ordering.
PostPosted: Jun Fri 07, 2019 3:19 pm
Looks like the lettering of “Micamold” also helps define the direction, so I think you’re right that the first is 3200 pF. That’s an odd value but must be correct. Maybe a padder capacitor?
The second one then would appear to be 250 pF.
Tom K6VL
PostPosted: Jun Fri 07, 2019 4:08 pm
Dennis wrote: viewtopic.php?p=1296489#p1296489
and...
Tom wrote: https://www.radiomuseum.org/forum/crosl ... ode.html#6
:) Greg.
PostPosted: Jun Fri 07, 2019 4:29 pm
32 is not a standard value, more likely 22000 pfd.
If voltage is not given, it's 500 volts.
That was standard for mica "domino" capacitors.
That's 250 pfd.
It's not unusual to find dot positions that are not used.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Jun Fri 07, 2019 4:40 pm
What radio, year, and model might help. I know you said the schematic is no help, but knowing what radio and year might help as others may have the same radio..
Paul of Florida
PostPosted: Jun Fri 07, 2019 4:59 pm
So they color coded it backwards?
That's 250 pfd.
Ah good to know, thanks.
It is a Sparton 68 from around 34-35
PostPosted: Jun Fri 07, 2019 6:12 pm
Large schematic→ https://a4.pbase.com/o12/56/215056/1/16 ... titled.png
To convert from μF to pF
Here's a handy capacitor conversion chart.
http://justradios.com/uFnFpF.html
μF (microfarad)
pF (picofarad)
Random examples...
.002μF (microfarad) equals 2000pF (picofarad)
.00025μF equals 250pF
PostPosted: Jun Fri 07, 2019 6:39 pm
The parts list on the schematic that Greg posted does show a .0032mfd capacitor.
So apparently this set predates the value standardization era, or they needed an odd value.
Sorry for the digression.
- Leigh
73 de W3NLB
PostPosted: Jun Sat 08, 2019 12:32 am
Fixed value padder capacitors tend to have odd values, and be fairly large micas like this one. They need to be reasonably stable to prevent tuning drift, and the odd value is needed so that the dial span covers the intended range and tracks with the other tuning gang, which is frequency shifted by the IF frequency.
Tom K6VL
PostPosted: Jun Sat 08, 2019 1:37 am
Oh I thought they were molded paper type, then if it's mica there is no need to worry then.
However I found I over looked one capacitor at the top of the chassis. It is a micamold as well, but a large cylinder style, threaded base with three wires, Red, White (Maybe yellow), and black out of the bottom. The label isn't in great shape, but tried to do a better job with the picture.
Am I just blind and missing the mfd value?
PostPosted: Jun Sat 08, 2019 1:46 am
That’s a dual section electrolytic cap. C13 on your diagram. Two sections of 8 uF each. You can replace it with two separate 10 uF 450 V electrolytics. If you want to play it safe, use 500 V electrolytics, even though the originals were 450 V.
I don’t think I’ve seen one of those made by Micamold before.
Tom K6VL
PostPosted: Jun Sat 08, 2019 2:08 am
The two eights appear to be under the orange marking.
Is the original rating (working voltage) not 480V?
PostPosted: Jun Sat 08, 2019 2:23 am
Ah, Thanks for the help.
PostPosted: Jun Sat 08, 2019 3:39 am
Enlarged picture, is not 460 V.W.. mean 460 voltage working, and 525 V.S.P mean 525 Volts Surge Protection ? (All on the same line)
Paul of Florida
PostPosted: Jun Sat 08, 2019 3:59 am
V.W. volts working.
Working Voltage. The (usually maximum) voltage at which a circuit or device can be operated continuously with safety and reliability.
V.S.P. I think is voltage supply peak.
:) Greg.
Post New Topic Post Reply  [ 29 posts ]  Moderators: Marcc, Norm Leal Go to page 1, 2  Next
Users browsing this forum: Exabot [Bot], Google [Bot] and 11 guests
