It is currently Dec Sat 14, 2019 3:55 am
Post New Topic Post Reply  [ 55 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Zenith Trans Oceanic L600
PostPosted: Jun Wed 12, 2019 9:10 pm
KD4KO wrote:
I cut the plate wire of the converter tube and applied power; still get moter boating sound.
I did the same to the plate of the IF AMP; still get motor boating sound.
I do not recommend that approach. Disconnecting tube plates can change the DC voltage throughout the set, which in turn can give new symptoms and/or mask the ones you already have.
To test for oscillation stage by stage, tack in a 0.01 capacitor from various tube grids to ground. This kills the gain of the stage.
-Mark
PostPosted: Jun Wed 12, 2019 11:04 pm
I will do as suggested, but I'm trying to understand where the audio comes from, that is applied to thr top of the volume control.
PostPosted: Jun Thu 13, 2019 12:16 am
My Schematic printout is hard for my aged eyes to read clearly; however under magnification, I can see what i thought was a crossover from the bottom of IF Transformer A1 was in fact a faint dot connection.
PostPosted: Jun Thu 13, 2019 12:46 am
I much prefer to work with a printed circuit with axial lead components than this hand-wired mess.
I would like to temporally disable the AVC circuit, to see if it stops the motor boating.
PostPosted: Jun Thu 13, 2019 12:58 am
The output of the 2nd IF transformer--high side-- goes to one of the diodes in the audio tube. This rectifies the IF signal to have a negative DC component, with the audio superimposed. The volume control is the branch point. AGC DC voltage to the left, and audio through the cap from the wiper
-Mark
PostPosted: Jun Thu 13, 2019 10:15 am
You explained what I just independently discovered this morning.
https://web.archive.org/web/20101104233 ... ervice.pdf
The above schematic cleared things up for me. I can now see the diode anode of the detector and the capacitor at pin 3 of T2 that strips the RF from the audio.
I remember in 1946, while 12 years old, experimenting with a rectifier tube as a detector, instead of the Galena crystal in my crystal set.
I thought I had discovered something when I placed a capacitor across the earphone connections and notice an increase in the audio level. I sent a letter to a Hugo Gernsback publication about this increase of audio, and was told about the RF being shunted to ground.
PostPosted: Jun Thu 13, 2019 4:42 pm
pixellany,
I thank you for your patience with me. You have been very helpful.
I removed the two AVC paths, but I still get the motor boating sound, coming from the L26 secondary.
I'm going to take a long break, and give my eyes a rest.
PostPosted: Jun Fri 14, 2019 3:31 am
Have you replaced C26, the 12 µF electrolytic?
PostPosted: Jun Fri 14, 2019 3:36 am
KD4KO wrote:
In line capacity of C1 A B C are correct, I isolated C1 D and it is 100MFD.
Regardless of their capacitance reading, they should be replaced. They are probably leaky, and may have high ESR. Have you replaced them?
PostPosted: Jun Fri 14, 2019 11:59 am
C26 is shown in schematic;
But shown as C2 in schematic ;
I cut the positive lead of this capacitor and turned the radio on. It still gives the same sound.
This put-put sound is applied to the VC via pins 4,6 of the secondary of T2.
PostPosted: Jun Fri 14, 2019 12:07 pm
You need to replace it, not cut it out of the circuit.
PostPosted: Jun Fri 14, 2019 1:51 pm
First, get the set in the correct configuration--all capacitors connected, all resistors connected, everything the right value, tube shields in place and correctly grounded......etc
Attempt to trouble-shoot only when it is in the right configuration
How about my earlier suggestion about tacking in a small capacitor to kill the gain of a stage?
-Mark
PostPosted: Jun Fri 14, 2019 2:25 pm
Have we even established that he's replaced all the electrolytic capacitors? Poor power supply decoupling would be my first guess as the cause of motorboating.
PostPosted: Jun Fri 14, 2019 2:56 pm
There was discussion at the beginning about the specs for replacement electrolytics, so I assumed it was done.
Indeed---replace all known "problem" parts--all electrolytics and paper/wax capacitors, out of tolerance resistors, etc. before trouble-shooting.
-Mark
PostPosted: Jun Sat 15, 2019 1:16 am
I have ordered five .01uf Metallized polyester 400V axial lead capacitors from eBay.
I also need .001 & .047 axial lead capacitors. any source in mind?
It is a real pain, not being able to go to a local electronic parts store any longer!!!
PostPosted: Jun Sat 15, 2019 1:20 am
Many of us get capacitors from either JustRadios or Sal's---both have ads on the right hand side of the page
-Mark
PostPosted: Jun Tue 18, 2019 6:28 pm
While waiting for the .01 caps to arrive, I decided to use a 50 volt 1.0 uf Bi-Polarized Cap instead.
Shorting the control grids of V1- V3 have no effect on the motor boating.
By-passing the wiper of the VC, stops the sound as expected, however by-passing the hot end of the VC, has no effect.
PostPosted: Jun Tue 18, 2019 9:01 pm
The audio output tube is the single biggest consumer of B+ power in this radio (or just about any other tube radio you can name).
Often a "motorboating" noise is caused by the high current demand of the output tube momentarily pulling down the B+ bus voltage, the effect of which "feeds back" throughout the audio section. The result is an audible "pock" sound from the speaker. This feedback path has a time constant: once the B+ bus recovers, the output tube kills it again, and the cycle repeats ad infinitum.
Where the problem appears to be isolated to the audio stage, this is caused by a defect in the B+ supply such that the B+ bus cannot supply enough current to resist having its voltage level pulled down by the demands of the output tube.
Sorry, I didn't bother to carefully follow the thread of what has been done to the set up to this point; but the two "most likely suspects" are the selenium rectifier and the electrolytic filter cap.
One thing to try would be to power the radio off of dry cells, bypassing the AC power supply. A stack of ten 9V transistor-radio batteries plugged together in series works well for the B+ supply; six "D" cells in series will power the filaments for a long time. If the motorboating ceases when running on batteries, that pretty much indicts the AC power supply.
PostPosted: Jun Wed 19, 2019 12:57 pm
I will pick up the 9v batteries today.
I'm also going to replace the AC filter capacitors.
I would like gut the original, and insert the new caps in its sleeve if possible.
PostPosted: Jun Wed 19, 2019 2:31 pm
I don't like to promote products or services that I've personally not tried, but I've heard good things about this:
https://hayseedhamfest.com/collections/ ... eanic-l600
Yes, it's possible to "cut and gut" the existing cap and restuff it. I've never done it on a TO (I just disconnect the original multicap and install new axial-leaded discrete electrolytics under the chassis).
Take note that the metal shell of the multicap goes to the B- bus, NOT chassis ground.
Post New Topic Post Reply  [ 55 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1, 2, 3  Next
Users browsing this forum: 5Y4GT, Lolyn and 11 guests
