It is currently Oct Sat 19, 2019 3:25 pm
Post New Topic Post Reply  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Replacing seleniums in a Perma Power
PostPosted: Jun Tue 18, 2019 10:03 pm
OK, I am reading 116K ohms from B+ to B- on the radio. Since I have done no work on the radio itself I am looking for suggestions to substitute a load to place on the Perma Power to figure out an appropriate dropping resistor for the B+ supply.
Jim
KE8GMW
"AC volts and DC volts and little lamps and lities..."
PostPosted: Jun Wed 19, 2019 1:16 am
If the radio isn't playing, the 116 K may be leakage or
a bias divider.
Why would you need to drop the voltage ? It already has
a voltage divider, with , if custom holds, 10 % of the expected
load flowing with nothing connected
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jun Wed 19, 2019 9:22 pm
The radio is still all original underneath and some of the dogbone resistors have cracks in them. I also replaced the original selenium with a silicon diode which has a lower forward voltage drop along with newer capacitors. That is why I am asking the question .
As it stands now without an extra dropping resistor, the no load readings are 135,125,114 and 101 volts for a 92 VAC input. I am looking for readings of 135,112,90, and 67 volts under load with a 120 VAC input.
Jim
KE8GMW
Post New Topic Post Reply  [ 23 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1, 2
Users browsing this forum: Jimmler and 2 guests
