It is currently Jul Thu 18, 2019 9:46 am
 Post subject: using modern headphones on a hallicrafters sw 500?
PostPosted: Jun Sun 16, 2019 6:38 am
ETA Would I be ok just using modern headphones with greater than 50 ohm impedance? I didn't realize that these were available, but apparently I am an idiot.
I've been doing some searching, and it seems most just use the old style high impedance headphones. I'd rather not have to go that route if possible.
Has anyone either converted their radio or made an adapter box to use modern headphones? I'd even be interested in a "store bought" solution.
The pictures I have seen in the for sale section all seem to show the old headphones having some sort of tips on the ends, vs a 1/4 inch type jack. My radio has the more modern 1/4 inch jack style, but it takes the high impedance 50 to 10K ohms headphones.
Russ
 Post subject: Re: using modern headphones on a hallicrafters sw 500?
PostPosted: Jun Sun 16, 2019 11:13 am
Like many modern sets, the headphone jack for the SW500 is in the same circuit as the 8 ohm speaker. Nearly all modern headphones or even an external speaker plugged into that jack should work just fine. For stereo or smaller headsets with 1/8" plug, you can just use a simple (stereo to mono) plug adapter.
PostPosted: Jun Sun 16, 2019 3:44 pm
The phones you use may injure your hearing, or someone else's.
A pair of 2000 ohm headphones cannot draw more than .06 watt
from an 8 ohm, 1 watt source.
Do consider someone sitting down, not hearing anything in the phones,
even though they cranked the volume up all the way. Then they notice
the standby switch.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jun Sun 16, 2019 6:06 pm
A series resistor or an L pad will limit the maximum power to the headphones. The value will depend on the phones. A small pot would let you set the attenuation to match the phones.
You can assemble a little box for the attenuator, with a plug for the radio and jack for the phones. Ideally, the plugs and jacks could be different enough so the phones cannot be plugged directly into the radio.
Ted
PostPosted: Jun Sun 16, 2019 10:10 pm
In years past, stereo headphones meant to attach to an amplifier, say to speaker
system B, were sold with a jack in small tube that added series resistors.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jun Sun 16, 2019 10:32 pm
We are adults here. We should be awake and aware. Turn the volume down before plugging in the phones or switching from standby.
Yes, ordinary headphones with a mono-stereo adaptor will work.
cheers
EDIT : typo
PostPosted: Jun Mon 17, 2019 12:18 am
The modern phones need not be 8 ohms.
Some sort of attenuation may be desirable just to knock down the volume-down hum and noise you will hear. It's nice to adjust things so the volume in the phones is reasonable at the normal volume control setting.
Ted
PostPosted: Jun Mon 17, 2019 12:53 am
We certainly are adults, and those who lived through the stereo amplifier era, at
least from a service point of view, experienced the scenario of blown speakers, and
transistors, from cranking volume, then flipping the tape monitor switch off.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jun Mon 17, 2019 1:38 am
Another factor: hum might be considerable in headphones, even if it's barely audible in a speaker. Attenuation will take care of that.
PostPosted: Jun Mon 17, 2019 7:22 am
Thanks, all.
I will be the only one using this. Just me and my wife, well we have a cat and dogs, but none of them are interested at all in this except for me. :lol:
I found a pair of Sony headphones that are 60 ohm impedance, might give them a try. Not too expensive. Will continue to look around for now. If all else fails, I will use a pair of cheap headphones I have laying around for now.
Russ
PostPosted: Jun Mon 17, 2019 9:52 am
:D
well we have a cat and dogs, but none of them are interested.jpg [ 72.26 KiB | Viewed 160 times ]
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jun Mon 17, 2019 1:14 pm
Russ
YES Your making an issue where there isn't one. If you already have a decent set of stereo headphones with a 1/4" plug just plug them into the radio. You will hear only one Ear because the headset is stereo and the plug is stereo. So you need an adapter stereo to mono 1/4". Or if your headset has the small plug on it then you need a 3.5mm = 1/8" stereo to 1/4" mono adapter. As to sound level that's what they put a volume control on the radio for. I'll give you an example. Here I have my nearly NEW ham radio transceiver. It is designed to hook up an 8 ohm speaker and yes I do have one. I also have a couple pairs of headphones. These also have a Mic hanging on the headset. The Heil Pro Set I have I know has 200 ohm small speakers built into a very comfortable to wear cushioned headset. The other set is a Yamaha stereo headset with boom mic and it too is I am sure probably in the same range of 100 to 200 ohms PER SIDE. Well the first thing that happens when you parallel TWO earphones together for MONO use rather than Stereo is that 200 ohms becomes 100 ohms.
As to any reference to "High Impedance Phones" that would be talking about headsets from back in the 20's & 30's when Speakers as in HORN SPEAKERS were also High Impedance. By high we are talking about 2000 ohms per ear or per speaker. They are uncomfortable to wear as well as the sound quality of those early headsets or early speakers is terrible.
John k9uwa
Post New Topic Post Reply  [ 12 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Exabot [Bot] and 7 guests
