It is currently Jul Tue 07, 2020 8:35 pm
 Post subject: Zenith ch 6H02 question
PostPosted: Jun Wed 19, 2019 3:54 pm
I'm working on a Zenith H664 and recapping the 6H02 chassis . Should I use a safety cap when replacing C4 ,its 0.05uf @200v wax cap . The schematic is in Riders 22-13 if you can't see my scan .
thanks
 Post subject: Re: Zenith ch 6H02 question
PostPosted: Jun Wed 19, 2019 4:24 pm
Yes, it should be a "safety" cap. Justradios.com has a good writeup on how to select them.
PostPosted: Jun Wed 19, 2019 4:34 pm
Sams Photofact service manuals...
viewtopic.php?p=2840111#p2840111
PostPosted: Jun Wed 19, 2019 5:28 pm
thanks guys , I have read that just radios article , very good .
PostPosted: Jun Wed 19, 2019 10:41 pm
That radio has a number of capacitors that might be replaced with "safety" caps.
I'm looking at a copy of the Rider schematic from NA. You can read the component designations on this scan. (Note that Sams use different designations.)
Besides 0.05uF C4, which should be a Class Y cap, we see 0.01uF C8, which should be a Class X cap.
But there's more! Connected to the phono jack, 100pF C17, and trimmer C18, can also connect you to the AC line. 100pF Class Y caps are easy to find. For C18, your best bet is to connect a much larger Class Y cap in series between the jack and the trimmer. 0.001uF is probably large enough. 0.01uF would be OK, too.
Even with the "safety" caps, this unit can be a shock hazard. Be sure that any backs, covers, and all knobs are in place.
This is not the unit to use on your swimming dock, or by the bathtub.
Ted
PostPosted: Jun Thu 20, 2019 12:14 am
I forgot about C8 and didn't know about C18 thank you . The only expose metal on this radio is the record holding arm ,its a big hunk of Bakelite.
PostPosted: Jun Thu 20, 2019 4:11 pm
Between the phono jack and trimmer I could use any value between .001uf - .01uf ? I have some .0047uf X1Y2 caps .
PostPosted: Jun Thu 20, 2019 10:30 pm
Any fixed capacitance in series with the trimmer should be much larger than the maximum trimmer capacitance to avoid reducing the effect of adjusting the trimmer.
Also, a larger capacitance value will reduce how much the tempco of the fixed capacitor matters.
I'm not sure how much adding such a capacitor would actually help decrease the chances of having a shock hazard.
Ted
PostPosted: Jun Thu 20, 2019 11:13 pm
Thanks Ted , I'll leave that as is and replace the 100p cap when my order comes in . The original 100p cap is rated 500v ,that could have been the safety cap of its day .
Post New Topic Post Reply  [ 9 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: detroitamplab, Google [Bot], jim rozen, JnTX, kenro4691 and 20 guests
