It is currently Jan Wed 20, 2021 2:56 pm
 Post subject: Crosley 106CP
PostPosted: Jul Thu 11, 2019 4:14 pm
Hi all, I'm new to the group and have a question about my restored Crosley 106CP. After a move to my new house, the receiver (mainly AM Broadcast) has lost all sensitivity. If I hold my hand on or near the variable tuning capacitor the reception improves dramatically. Any thoughts on what to pursue next? Perhaps time to break out the tube tester, when I can find it!
Also, I 'm looking for replacement knobs. Any suggestions would be greatly appreciated.
Anson
 Post subject: Re: Crosley 106CP
PostPosted: Jul Thu 11, 2019 4:27 pm
Most likely a broken connection to the loop antenna. It should be in the bottom part of the cabinet and connect to the radio chassis with two wires.
Jay
PostPosted: Jul Thu 11, 2019 4:29 pm
Does your new house have aluminum or steel siding?
PostPosted: Jul Thu 11, 2019 6:38 pm
Brick and frame house. The antenna assembly is intact although the insulation is breaking off in spots. I may try a different wire to see if that changes things.
PostPosted: Jul Thu 11, 2019 8:10 pm
If it is a newly built house, it may have a layer of aluminum foil in the insulation. I've found that to significantly reduce the reception in my house.
Jay
PostPosted: Jul Sun 14, 2019 7:09 pm
That looks like what should be a good performing radio. With a loop antenna you might try turning it to see if that helps. While I like loops, unless they are made to be rotated without turning the whole set, they can be a pain.
Another suggestion is to take the radio outside. If it works properly then you have your answer.
Tony
PostPosted: Jul Mon 15, 2019 4:50 am
Done the turning and antenna checks etc. I'm talking about a local AM station too. Almost no sensitivity until I pass my hand on or near the tuning cap. The Shortwave bands seem sensitive enough however. Oh well I will keep plugging away at it. As I said, it was recently rebuilt and worked well until I moved to a new location. I'm feeling that its a tube.
Post New Topic Post Reply  [ 7 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: alexandru_sorin and 21 guests
