It is currently Feb Tue 25, 2020 4:19 am
 Post subject: General Electric model 409 AM/FM table radio
PostPosted: Aug Fri 09, 2019 3:33 am
Hello all,
Was hoping to get some pointers on what I could try to get this ol gal up and working again. I was given a GE 409 radio and she's a looker. I pulled all tubes and checked each one measuring them around 64% condition. I replaced the capacitors including filter caps. Am portion is dodgy sometimes it works, FM side nothing at all. Both bands produce no audio other than a low soft hum thats it.
Ill be the first to tell you Ive never had any luck getting old radios that had FM working. I had a FADA once and gave it away because after several months of trying I said enough is enough. Now, I have another here on my bench and I am in hopes that someone might be able to shed a little light or point me in a direction.
Thanks!
 Post subject: Re: General Electric model 409 AM/FM table radio
PostPosted: Aug Fri 09, 2019 4:21 am
20-pages of service information... factory and Sams, thanks to Bill J.
viewtopic.php?p=2045538#p2045538
Expected V and R for all tubes, all pins, is shown on the Photofact schematic.
See legend (note) on same page.
PostPosted: Aug Fri 09, 2019 5:58 am
I think I own an example of this model. But I haven’t ever powered it up or checked it out yet. Must be time to do so now.
PostPosted: Aug Fri 09, 2019 4:22 pm
Richard aka richfair reported a successful (noise-free) LED 120V 3W lamp conversion here, via this link.
viewtopic.php?p=2803430#p2803430
PostPosted: Aug Fri 09, 2019 11:28 pm
I would start with a DC voltage check of the selenium rectifier. When they age, voltage drops.
If that is ok, I would try to get the AM band working, as it is simpler, and you had it sometimes working. Cleaning the bandswitch again might make a diff. With AM working, you know your audio section in good.
FM uses a different antenna and several FM tube stages before joining up with the audio section.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Aug Wed 14, 2019 4:21 am
Be sure and change the power switch from the return side to the hot side.
That keeps the live current away from always being on the chassis. Just so you Know :idea:
Visit our site:
I was smokinradios Long time ago (2004)
Post New Topic Post Reply  [ 6 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: atwaterkent1, battery-maker, davek65, Dirt Bomb, toxicology, Trent and 19 guests
