It is currently May Mon 25, 2020 4:50 am
 Post subject: Philco Model 60 Code 121 Questions
PostPosted: Mar Mon 23, 2020 6:07 pm
Hello, so I am working on doing an electrical restoration on my Philco Model 60, and it appears to be a 1935 model. I have a couple questions:
1. How do I read the style of domino Micamold capacitors? I just don't get it.
2. I noticed that one of the coils fell out of the IF can! The one with the wire coming out of it, a little black wire coil fell out. The radio currently works, but the AM is very patchy depending on how the coil is positioned. Also, the enamel is totally coming off. I could reseal it with some clear lacquer and put the coil back... What should I do? I currently have that IF transformer desoldered and removed.
3. What is the original voltages for the 8mfd filters? The schematic doesn't say...
Thanks!
I won't need to ask anything about the physical restoration, as my Dad was a cabinetmaker most of his life and he will refinish it, so that's nice.
 Post subject: Re: Philco Model 60 Code 121 Questions
PostPosted: Mar Mon 23, 2020 6:29 pm
Philco part number 7558 is 8µF rated at 400V
Schematic and parts...
https://philcoradio.com/library/downloa ... l.%201.pdf
Evolution of Philco Model 60
https://philcoradio.com/library/index.p ... -model-60/
from here: https://philcoradio.com/library/
Philco components, their part numbers and values,
+1936 parts catalog...
viewtopic.php?p=2960860#p2960860
PostPosted: Mar Mon 23, 2020 6:33 pm
Thanks for confirming that putting in a 400 volt capacitor is fine! I did find the model 60 evolution page before, which has been helpful!
PostPosted: Mar Tue 24, 2020 5:26 pm
I determined the coil that fell out is part of the antenna coil, and is bypassed when the radio is put into police mode. How can I repair/rewind this coil? Does it need to be wound in the same fashion? It's the coil with the 10k resistor across it in the schematic, between the antenna and the .7 ohm coil and ground.
Thanks!
PostPosted: Mar Tue 24, 2020 7:39 pm
Here is a photo of the coil... You can see all of the lacquer damage. How would I go about rewinding this coil?
File comment: Image of Coil
PostPosted: Mar Sat 28, 2020 2:04 am
Sorry to bump, but do I need to use the same gauge of wire to rewind this? I seem to have read that this part isn't in the tuned circuit, so it just has to be close. I can't even wind that crisscross style of winding I don't think. Is there anything I can do? Or do I have to buy something to fix this?
Thanks!
PostPosted: Mar Sat 28, 2020 2:25 am
Some informative links here...
philco 60 antenna coil site:antiqueradios.com
https://www.google.com/search?q=philco+ ... radios.com
https://philcoradio.com/phorum/showthread.php?tid=4675
View Single Post 75 - - see thread... Philco 60 restoration
http://www.videokarma.org/showpost.php? ... stcount=75
Greg/I previously wrote: You could measure the Magnet wire (enameled wire) with a pair of digital calipers, and find the nearest AWG (gauge).
Magnet wire can be found inside all types of electric motors, large and small.
Old (electrical) home appliances, windshield wiper motors... et cetera.
+eBay and on-line sellers.
Don't spend more than 20 bucks on a pair of calipers.
https://www.harborfreight.com/6-in-Digi ... 63731.html
Count the number of turns, and re-wind.
Gently scrape the enamel off the ends to solder. Use a sharp X-ACTO knife or a razor blade.
PostPosted: Mar Sat 28, 2020 2:40 am
Thanks for the info. The problem is it's that inner coil that goes inside the tube which has fallen out. It isn't actually open, but the enamel is just falling off it like crazy. The outer windings are fine. The inner coil is wrapped around a piece of felt, and goes between two positions of the band selector, and is shorted when in Police mode. It's also wound crossways, which you might be able to see in the picture.
I would guess I would have to find a pen or something to wind around and figure out how to emulate that winding style?
Thanks!
Post New Topic Post Reply  [ 8 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Google [Bot], lorenz200w, Majestic-12 [Bot] and 9 guests
