It is currently Oct Thu 29, 2020 1:12 am
 Post subject: Safety capacitor on crosely 529
PostPosted: Sep Fri 18, 2020 1:54 am
Would the #13 capacitor on this Crosely 529 radio schematic be the one that needs to be a safety cap? It call for .05uf cap, i have a .01 safety cap. Would that be ok?
schematic 529 crosely.pdf [160.13 KiB]
Downloaded 27 times
 Post subject: Re: Safety capacitor on crosely 529
PostPosted: Sep Fri 18, 2020 2:19 am
The #13 cap can be type X2 or Y2 since it is line-to-line and not line-to-chassis. A 0.01uF will be OK.
I would move the right end from pin 3 of the 35Z5 to pin2. When the cap is on pin 3, even a temporary short in the cap will burn out the rectifier.
Type X and Y caps can short due to high transient voltages but are designed to burn out the short and continue to function.
Edit: They probably put the original cap on pin 3 of the 35Z5 so the tube would act as a fuse. When the original, non-safety, caps shorted, they would often explode. Better to sacrifice the 35Z5 than set the house on fire.
Jay
PostPosted: Sep Fri 18, 2020 2:30 am
Will do. Thanks
PostPosted: Sep Fri 18, 2020 1:27 pm
The 0.05 uF cap was no doubt chosen to control RF noise and interference that could be picked up by the cord and AC power wiring. There’s actually a lot more of that around today than in the past. If the radio seems noisy or buzzy afterward you might want to re-visit this and put a 0.05-uF back in.
PostPosted: Sep Fri 18, 2020 2:45 pm
ok :)
Post New Topic Post Reply  [ 5 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: bob_u, cwysong, Mr. Detrola, VEK and 23 guests
cron
