Forums :: Web Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives
It is currently Mar Fri 24, 2023 12:44 am
 Post subject: Philco Broken Pushbutton Power Switch Solution
PostPosted: Oct Mon 12, 2020 4:34 pm
Philco sets in the 1940's often had pushbuttons on the front panel and one would be used as an On/Off switch. I have seen several broken ones and have added a small switch on the back panel. Customer did not want that done and suggested a new volume control with switch on the back. Here is a neater solution. Switch only costs $0.39. The only modification required is to enlarge the hole to clear the shoulder on the switch.
https://www.xump.com/science/Push-On-Pu ... fm?SID=226
Dale
http://www.dalesantiqueradio.com/
 Post subject: Re: Philco Broken Pushbutton Power Switch Solution
PostPosted: Oct Wed 14, 2020 1:27 am
VERY NICE Dale. Thanks. I used one of the usual PB switches from the local big box store the last time around and was totally UN happy with it. Ended up actually changing out the tone control for one that had a switch on it. But this is MUCH BETTER solution. Yes I ordered some of them.
John k9uwa
http://www.JohnJeanAntiqueRadio.com
Post New Topic Post Reply  [ 2 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: N9whh and 215 guests
