It is currently Nov Thu 26, 2020 2:32 pm
 Post subject: Sparton Surprise
PostPosted: Oct Thu 29, 2020 3:57 am
First Sparton I have worked on. When replacing caps I always cut the leads off right at the cap and then try to remove the remaining wire. Most mfrs wrap the lead tight and Philco wraps the lead around as few times. Sparton just bends the lead in an L shape. You heat the joint and push the lead out, clean the hole and insert new component.
Dale
http://www.dalesantiqueradio.com/
Post New Topic Post Reply  [ 1 post ]  Moderators: Norm Leal, Marcc
Users browsing this forum: brnhornet52 and 25 guests
