Author |
Dennis Wess
Post subject: Shaft Extender Ideas - JOB COMPLETED Posted: Mar Thu 24, 2022 4:58 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2505 Location: Sterling Heights, Michigan 48314, USA
I had to replace the volume/pwr switch pot on my Philco Hippo. I need to extend the shaft on this pot. I removed the brass shaft from the original bad pot and am hoping to use it to extend the shaft on the new one. The shaft needs to end up at the height shown in the photo below. Any ideas on how to securely attach the extension ? I will use my Dremel to cut the brass extension to the required length-- once I know how I'm going to proceed..
_________________ .....Dennis.....
Live Long and Prosper
Top |
Mr Peabody
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 5:32 pm |
Member |
Top |
Rich, W3HWJ
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 5:41 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 11300 Location: Santa Rosa, CA
Top |
John Bartley
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 5:44 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12032 Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K 1P0
I did one many years ago fr a member. I ground the pot shaft with a flat section made to be an opposite to the extension, meshed the two and held them together with a brass tubing that I heated to expand and then pressed on over the joint and let cool to shrink. As far as I know it worked. cheers John Attachment:
Top |
lorenz200w
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 5:51 pm |
Joined: Jan Mon 16, 2012 4:15 pm Posts: 9042 Location: Near Brandon, Iowa
Purchase a 12 inch length of thinwall brass tubing, ID=0.250 inch, from a local brick-and-mortar hobby store. or an internet hobby store. K&S Metal Shapes is a commonly-seen brand. Also purchase an inexpensive razor saw with which to cut the tubing.
Slice off a length of tubing about an inch and a half long, and debur the cut end with sandpaper. It should fit perfectly over both the original shaft and the extender.
Now you have an option: you can either abrade the shaft ends with a file or sandpaper so that they will have "tooth" for the epoxy that you will use to join the shafts; or you can file a half-round for a half inch or so in each shaft end such that they will interlock with each other. The abraded approach is fine for low-torque applications like volume controls, but for extending bandswitches I prefer the "stepped ends" idea.
When you have the shafts cut and prepped, slather the abraded ends with J-B Weld epoxy and fit the two shafts inside the tubing. Use denatured alcohol to clean off excess epoxy that oozes out before it cures.
Immobilize the joined shafts while the epoxy cures, ensuring that the assembly is perfectly straight. Once you get it straight, don't touch it for 24 hours.
If you mess up (possible to do but not very likely) and you need to remove the extension shaft, clamp a vise-grip near the chassis end of the original shaft to serve as a heatsink, then heat the coupling with a small butane torch. When the epoxy gets hot enough it will turn to goo and the shaft and coupling tube can be pulled apart. The spent epoxy residue can be wiped of with an acetone-wetted paper towel.
Top |
egg
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 6:40 pm |
Member |
Joined: Jan Tue 31, 2012 1:55 am Posts: 20167 Location: Mountains of Mourne. Ireland.
Half lap them with a second cut file, and add two hose clamps.
Top |
lorenz200w
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 6:56 pm |
egg wrote: Half lap them with a second cut file, and add two hose clamps. Double layer of heatshrink tubing instead of the clunky clamps! The possibilities are (almost) endless.
Top |
fifties
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 7:16 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 40442 Location: SoCal, 91387
I've used a section of a telescoping antenna as a sleeve, length cut to fit, and secured with crazy glue if necessary.
_________________ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins/////////////////////////
Top |
egg
Member |
Top |
Govee
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 7:43 pm |
Joined: Jan Tue 29, 2019 7:01 pm Posts: 542 Location: 20653
I found a 1/4" ID coupler at Lowe's for a dollar. fits the shaft diameter perfectly on my rca 813k.
Attachments: |
Top |
Paul Dietenberger
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 7:48 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4558 Location: Oak Creek, WI USA 53154
I bought the shaft couplers on Amazon awhile back for a radio but they were so thick and clunky I had problems with where they passed through the cabinet.
Then I bought the 1/4" ID thinwall tubing mentioned above and JBWelded the shafts and thinwall tubing together. That works much better.
Top |
lorenz200w
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 7:56 pm |
Paul Dietenberger wrote: I bought the shaft couplers on Amazon awhile back for a radio but they were so thick and clunky I had problems with where they passed through the cabinet.
Then I bought the 1/4" ID thinwall tubing mentioned above and JBWelded the shafts and thinwall tubing together. That works much better. The K&S thinwall tubing has 1/64th inch wall thickness. So the total increase in OD is only 1/32 inch, not likely to cause a mechanical interference problem. The Amazon shaft couplers were probably intended to solve heavy-duty problems. But, whatever works is a good solution.
Top |
Rich, W3HWJ
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 9:29 pm |
It amazes me what folks will do rather than just buy the right parts! Shrink tubing works in very low torque applications. Filing flats on a shaft is a lot work and hard to get really flat parallel surfaces. Heating brass tubing is about the best, but don't crush the tubing by using too much torque on the knob setscrew. Yes, I have tried all of these with varying degrees of success. So when I see shaft couplings, shaft sections, and panel bearings at ham swap meets, I buy them for a "rainy" day. https://mgs4u.com/product/14-to-14-shaft-coupling/https://www.rfparts.com/capacitors/capacitors-shaftcoupler.htmlRich PS: We forgot one other idea: drill and tap the existing shaft for a 6-32 screw (cut off the head). Drill and tap a 1/4 brass or aluminum shaft for 6-32. Screw the pieces together with a drop of thread locker or super glue on the screw.
Top |
egg
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 9:35 pm |
Member |
Obviously you've never been shipwrecked and stranded on a desert island. I'm done here.
Top |
John Bartley
Post subject: Re: Shaft Extender Ideas Posted: Mar Thu 24, 2022 10:30 pm |
Rich, W3HWJ wrote: It amazes me what folks will do rather than just buy the right parts!
Some of us have shops with tools .... Grinding a flat accurately on a shaft is a couple of minutes work. Joining the two with the flats together and held by brass tubing is very tight and straight Not every situation will accommodate those bulky shaft couplers. cheers John
Top |
Rich, W3HWJ
Post subject: Re: Shaft Extender Ideas Posted: Mar Fri 25, 2022 3:30 am |
Quote: Grinding a flat accurately on a shaft is a couple of minutes work. True, but I don't have a bench grinder; I only have a file. Rich
Top |
Rich, W3HWJ
Post subject: Re: Shaft Extender Ideas Posted: Mar Fri 25, 2022 3:33 am |
Quote: Obviously you've never been shipwrecked and stranded on a desert island. I'm done here Sorry, if I was a bit dismissive. I used to have a shop full of tools but everyone of them and 50 years of radio and test equipment collecting went to ashes in the 2017 Tubbs Fire. I have to buy rather than make most of the time. Rich
Top |
jim rozen
Post subject: Re: Shaft Extender Ideas Posted: Mar Fri 25, 2022 3:52 am |
Joined: Mar Wed 16, 2011 10:44 pm Posts: 2288 Location: Peekskill, NY
Please don't use a bench grinder for aluminum or brass.
Top |
fifties
Post subject: Re: Shaft Extender Ideas Posted: Mar Fri 25, 2022 4:22 am |
Member |
egg wrote: Obviously you've never been shipwrecked and stranded on a desert island.
With a Basketball named Wilson as a companion?
Top |
analog.tv
Post subject: Re: Shaft Extender Ideas Posted: Mar Fri 25, 2022 2:24 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2597 Location: Lafayette, CO
I take the control apart and replace the shaft with one of sufficient length. There is a 'C' clip to be installed: cutting the ring it sits in is easy with a drill and hacksaw blade. Keep it simple. Craig
Top |
