It is currently Nov Mon 29, 2021 10:42 pm
 Post subject: Curtis Mathes Fuse?
PostPosted: Sep Sun 05, 2021 9:31 pm
Hello,
I am working on a Curtis Mathes tube amp/tuner and the separate mains trans has a wire fuse which I think would be good to replace with a glass one....what do you think the rating of the new fuse should be?
Thanks.
 Post subject: Re: Curtis Mathes Fuse?
PostPosted: Sep Sun 05, 2021 9:49 pm
That looks like a 6.3VAC winding. I think the #26 wire is a good choice for the fuse.
Jay
PostPosted: Sep Sun 05, 2021 11:50 pm
You won't be materially improving the unit if you change to a plug-in fuse. The heater bus almost never fails and that's why probably less than 2% (my guesstimate) of radios with power transformers ever made were so fused. Count yourself fortunate that your CM rig provided protection against this unlikely failure, and leave the factory protection implementation alone.
PostPosted: Sep Mon 06, 2021 12:00 am
Thank you Lorenz, as always your frankness is appreciated......
PostPosted: Sep Mon 06, 2021 3:04 am
The inrush current for the tube heaters can be significant and last for several seconds. You may have a hard time finding a suitable glass fuse that will still give protection without nuisance blowing. Keep the wire.
Post New Topic Post Reply  [ 5 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: NormanG, WoodchuckTN and 32 guests
