It is currently Feb Tue 18, 2020 8:50 pm
 Post subject: What lacquer for brass trim?
PostPosted: Sep Wed 11, 2019 9:17 am
I need to lacquer for some cleaned brass trim, only small pieces, so I'm reluctant to buy yet another can of a specialised product.
I have both acrylic and cellulose sprays: will either of those do the job and stay on and last?
thanks Gary
 Post subject: Re: What lacquer for brass trim?
PostPosted: Sep Wed 11, 2019 2:41 pm
Cellulose...
Do so when the humidity is low.
I have found acrylic to be consistently cloudy to some extent and has a faint glow of blue in sunlight, (uv reaction). Did not adhere well to the metal either...
If you have transparent toner lacquer, that could be interesting if applied heavy and low areas get thicker coating. It should cause a burnished look with high areas having less shading than the low areas.
If not, easy clean off with thinners...
YMMV
Chas
PostPosted: Sep Thu 12, 2019 10:33 am
Thanks Chas
Have plenty of Mohawk lacquer so will use that.
Gary
PostPosted: Sep Tue 17, 2019 7:29 am
Site Admin
A couple of tips: Rinse the brass well with water and dry making sure you don't touch the surface. Oils from your skin will hasten the lacquer failing in the future.
Set the parts in direct sun on a warm day for several minutes before spraying them. This allows the brass to expand before the lacquer film is applied, preventing microscopic cracks occuring as the metal is subjected to varying temperatures in the future, which will allow the formation of microscopic cracks in the surface, hastening tarnishing.
PostPosted: Sep Tue 17, 2019 7:56 am
Good tips, thanks Alan
Gary
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
