It is currently Jul Sun 25, 2021 1:17 pm
 Post subject: Stuck Piano Hinge
PostPosted: Jul Sat 17, 2021 12:51 am
I have a Zenith 7000-2 that the rear cover hinge is frozen. I was able to open the cover enough to remove the screws that attach it to the case. I’ve tried wd40, Blaster, Machine oil. I’ve tried tapping it while drenched in each of these. I even tried punching the end of the wire of the hinge with a center punch, thinking it would break it loose. I’m having no success. Does anyone have a trick they’d like to share?
Rick
 Post subject: Re: Stuck Piano Hinge
PostPosted: Jul Sat 17, 2021 6:43 am
Is it rusty in any way? Electrolytic rust removal might fix it, I have undone rusty threads by that method.
Regards
Arran
PostPosted: Jul Sun 18, 2021 1:40 am
Regards
Arran
The plating is peeling off, but there is no noticeable rust. I figure that the hinge is made of dissimilar metals that have corroded together. I’m considering trying to suspend the hinge in a tub of Blaster. I just need to keep the back cover clear, which is only about 1/8” away.
Rick
PostPosted: Jul Sun 18, 2021 9:57 pm
You could try soaking it in Kroil. That stuff works wonders.
PostPosted: Jul Tue 20, 2021 4:58 pm
I make my own rust penetrating lube by mixing half automatic transmission fluid and half acetone.
Scott
If you can't explain it simply, you don't understand it well enough
A.Einstein
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
Users browsing this forum: Tin Omen and 8 guests
