It is currently Oct Thu 21, 2021 7:23 am
 Post subject: Dumont 1120 Clock Radio repair
PostPosted: Sep Mon 27, 2021 8:48 pm
 I'm restoring a Dumont 1120 clock radio.  Unfortunately all four screw posts have broken away from the cabinet.  I still have the broken posts attached to the screws.  Anyone know a good way to reglue the broken posts back to the cabinet?  Will JB Weld work??
 Post subject: Re: Dumont 1120 Clock Radio repair
PostPosted: Sep Tue 28, 2021 12:28 am
I've had good luck repairing broken pieces like what you show using epoxy glues targeted toward plastics. J-B Weld has a two part epoxy called PlasticWeld. Loctite also has their own version. Their bond is very strong. If possible after gluing squeeze the pieces together with a small spring clamp or use a weight of some sort. If necessary use a piece of wax paper or parchment paper between clamp and glued piece if glue may ooze out of hole in plastic to keep clamp from sticking. Good luck!
PostPosted: Sep Tue 28, 2021 5:53 am
It it's polystyrene plastic acrylic solvent cement from a plastics shop will weld the broken pieces of stud back together, with no clamps, which will result in a stronger bond, and a cleaner repair, then reaching for the J.B Weld, they sell it in some plastics shops. I don't know what it is about J.B but people seem to think it's the thing to reach for repairing anything, when it is not. It's almost as bad as this propensity towards using silicone on speaker cones, which should be left for caulking around the bathtub.
Regards
Arran
PostPosted: Oct Mon 04, 2021 5:16 pm
Agreed, solvent cement or airplane model glue, the stuff you shouldn't sniff.
The key here is to replace each piece exactly as it was before it snapped.
Those screws don't need to be torqued. It's not a truck wheel or cylinder head.
A firm but gentle touch on the screwdriver will do. :D
Burl Ives, RIP, oldtimer.
[:l>)
 Post subject: Re: Dumont 1150 Clock Radio repair
PostPosted: Oct Mon 04, 2021 6:55 pm
I'm gonna try SCIGRIP 10315 16 Acrylic Plastic Cement. I also just received a Bondic acrylic glue that UV light activated. I will test it out on some old plastic pieces, then give it a shot on at least one post.
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
