It is currently Oct Wed 20, 2021 7:51 pm
 Post subject: Questions on Tolex
PostPosted: Oct Mon 04, 2021 2:54 pm
Replacing all the rotted tolex on a Zenith G505 cabinet.
I found a source of tolex but I see where they call for Tolex Glue.
Stuffs pricey for what little I will use it.
Would it be okay to use contact cement?
Sam
 Post subject: Re: Questions on Tolex
PostPosted: Oct Tue 05, 2021 2:52 am
The fabric used on most tube type T.Os was a form of oil cloth, Tolex is more like vinyl, and the texture is different. Contact cement will work just fine, no reason to buy a fancy, and expensive glue.
Regards
Arran
PostPosted: Oct Wed 06, 2021 1:45 pm
Contact Cement is used by most with Tolex. I've done a few TO's and found the Light Weight Black Bronco works the best. It's thinner and folds around corners much nicer. A lot easier to work with.
Freeman
PostPosted: Oct Thu 14, 2021 3:08 am
Someone said Weldwood Contact Cement is what to use.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter
