It is currently May Thu 28, 2020 4:49 pm
 Post subject: Plas T Pair Liquid ?
PostPosted: Jul Wed 12, 2017 4:20 pm
Is the PlasTPair liquid CA cyanoacrylate thin glue? I think it might be,anyone know for sure? Thanks
 Post subject: Re: Plas T Pair Liquid ?
PostPosted: Jul Wed 12, 2017 5:48 pm
Doesn't appear to be a CA or epoxy. The powder component is atomized plastic and the liquid component is a volatile solvent for the plastic. Mixing the two components dissolves the plastic in the solvent forming a paste and when the solvent evaporates, you are left with solid plastic. About the same concept as dry wood putty powder and probably has similar shrinkage issues.
PostPosted: Jul Wed 12, 2017 7:20 pm
It is a solvent consisting of two parts. Can't find the sheet at this instant. Will try to find it and report later.
Bruce
PostPosted: Jul Wed 12, 2017 9:31 pm
OK, dug out mine. The information sheet reads;
CONTAINS
Solvent contains Methyl methacrylate (CAS 80-62-6) and N,N-Dimethylaniline (CAS 121-69-7).
Powder contains Poly ethyl Methacrylate/methyl acrylate (CAS26572-20-3, Ethyl acrylate (CAS 140-88-5) and Benzoyl peroxide (CAS 94-36-0).
PostPosted: Jul Sat 15, 2017 5:39 pm
It is very good and works perfectly with Bakelite. Used it for more than a decade and it not only hangs in there but the temp. coef. must be similar 'cos when sprayed hair cracks don't appear later in the paint.
Gary
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
