It is currently Jan Fri 28, 2022 5:49 am
 Post subject: Atwater Kent breadboard profile
PostPosted: Jan Wed 03, 2018 4:41 am
I sure could use a drawing or a picture that would show the profile of board that was used on the 10C breadboard.
Ed
Picture from Radio Attic
 Post subject: Re: Atwater Kent breadboard profile
PostPosted: Jan Wed 03, 2018 4:45 am
I don't understand your question.
What do you mean by "profile"?
You realize you have three threads with the same title, yes ?? ?
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Jan Wed 03, 2018 6:26 am
Hi Leigh, I may need to have a router bit ground to produce the detail around the edge of the board.
When I was posting it my machine locked up each time so the only thing I was able to do was to go back and delete the content, sorry.
Ed
PostPosted: Jan Wed 03, 2018 10:05 am
Hi Ed,
To the best of my knowledge there is no standard router bit for that board edge.
The question has come up before from other folks (though not on ARF AFAIK).
- Leigh
73 de W3NLB
PostPosted: Jan Wed 03, 2018 6:25 pm
I have someone that will grind one for me, he makes router bits so I just need to find the correct pattern
Ed
PostPosted: Sep Wed 08, 2021 5:56 pm
Did you ever get a spec drawing of the profile? If so could I get a copy?
Andrew
