Author |
fred taylor
Post subject: Majestic 1250 cabinet overhaul (FINISHED) Posted: Oct Sun 08, 2017 6:22 am |
Joined: May Fri 10, 2013 4:09 am Posts: 2281 Location: Dallas, TX
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Sun 08, 2017 6:25 am |
Speaker is ready
Attachments: |
File comment: Nice 15 incher.
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Mon 09, 2017 4:31 am |
Top |
Radio Fixer
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Mon 09, 2017 8:41 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3625 Location: Nr London, England, SS1 3PT
As always looking beautiful Fred
Gary
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Mon 16, 2017 2:22 am |
got some work done today on the cabinet, I didn't want to have to replace the veneer on the top section of cabinet but the veneer was bad, Something soaked into it over the years and I think it was an oil of some kind. The veneer would not sand properly and was very soft. So sparing no time I removed it and replaced with a book matched walnut and with maple strips. Everything will be stained and toned for the deferent woods to come together, should look wonderful with all new veneer. Mahogany on both sides, walnut burl on the upper side of the shoulders and walnut vertical columns, with zebra book match lower center section. Inside cabinet was painted dark blue as factory, also added 4 new metal floor guides to keep radio cabinet off the floor and easier to side on floor. Next week I hope to get the color on and get it sealed and perhaps get the clear coats applied. Chassis may be getting a new chrome job, its rusty and is in bad shape, so I may have to bite the bullet and get it re chromed. If you didn't notice I switched the zebra veneer I put on the vertical columns back to walnut, just didn't look right. also the top had sunk down a little and I had to fill and re level it , so now the top is perfectly flat again.
Attachments: |
File comment: Veneer was soft and could not be saved, seemed like some type of oil got on the top, sanding it was impossible.
File comment: Removing veneer on top, it was bad. Could not sand it, the sand paper would clog up.
File comment: Straight edge shows how much the top had sunk down in the middle., would not look right even with new veneer.
File comment: After filling and block sanding I got it flat, so now the veneer will look flat, like it suppose too.
File comment: Nice edge joining the walnut and the maple.
File comment: Nice and tight, and flat.
File comment: Very nice grain pattern on the walnut. Should look outstanding when finished.
File comment: Escutcheon gives me a glimpse of what its going to look like.
File comment: Looking sweet.
File comment: Fresh dark blue paint, outer edge of rear cabinet goes color of cabinet. Not much left of label but saved what I could.
Top |
Radio Fixer
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Mon 16, 2017 8:43 am |
Going to be a real handsome radio.
Look forward to the finished pics.
thanks Gary
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Thu 19, 2017 2:30 am |
Top |
Radio Fixer
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Thu 19, 2017 8:57 am |
Boy! that is one beautiful radio (even my wife thinks so; that's high praise) and will stand out from the crowd. Back in the day it was made, possibly buyers liked a more austere finish or it faded and lost some beauty (like we have  ; ). A lot of work to strip the chassis and have it re-plated but worth it for such a wonderful result. Is this one a keeper? Did you level the top with Bondo Fred? thanks for posting Gary
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Thu 19, 2017 12:12 pm |
Yes I am planning on keeping this one, it such a nice looking radio. I bet it will sound amazing given the tube count and the 15 inch speaker. I did use a type of bondo to fill the low area on the top..
Top |
Tepelus
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Fri 20, 2017 3:24 am |
Joined: Sep Sun 10, 2017 12:25 pm Posts: 21 Location: Nashville, MI
Top |
kc5gym
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Sat 21, 2017 12:40 am |
Member |
Joined: Aug Wed 26, 2015 9:41 pm Posts: 1384 Location: Baton Rouge, Louisiana
Outstanding! I wanna be like you, Fred, when (if) I grow up
_________________ Mark
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul Posted: Oct Sun 22, 2017 3:53 am |
Top |
ronij8
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Oct Wed 25, 2017 2:55 am |
Joined: Mar Sat 06, 2010 3:37 am Posts: 1159 Location: Broadview Hts. / NE Ohio
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Nov Wed 01, 2017 1:49 pm |
Top |
wyocodak
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Nov Wed 01, 2017 2:22 pm |
Joined: Dec Mon 21, 2015 7:59 pm Posts: 355 Location: Bucyrus, Ohio
Wow. I always love to see the beauty in the veneers and how they all come together. Thanks for the hard work you put in in saving this majestic radio.
Top |
Radio Fixer
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Nov Wed 01, 2017 2:33 pm |
Chassis turned out well; not original but worthy of the radio. Yes! having been there stripping and re-plating takes an lot of time.
What did you remove from the chassis to do the work?
Gary
Top |
ronij8
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Nov Wed 01, 2017 10:05 pm |
Love it Fred....looks great.
Lenny
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Nov Thu 02, 2017 12:47 am |
Radio Fixer wrote: Chassis turned out well; not original but worthy of the radio. Yes! having been there stripping and re-plating takes an lot of time.
Gary I removed the tuning condenser and the complete dial assembly, I masked off everything else. I have seen chassis come in wrinkle finishes before, cant remember which they where. I almost puked when I got into the chassis, it was the nastiness chassis I ever pulled from a radio , I thought about getting a shot from the doctor to protect me from the crap that was on the poor chassis.
Top |
doug-5er
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Nov Thu 02, 2017 1:44 am |
Joined: Apr Mon 09, 2012 2:55 am Posts: 2437 Location: Lakewood,SoCal- 90713
Stunning, just stunning excellent work as always Fred.
_________________ Doug
***"Your best teacher is your last mistake"***
Top |
fred taylor
Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED) Posted: Nov Sat 25, 2017 2:30 am |
Top |
Users browsing this forum: No registered users and 13 guests |
