It is currently Jan Wed 20, 2021 2:35 pm
 Post subject: Majestic 1250 cabinet overhaul (FINISHED)
PostPosted: Oct Sun 08, 2017 6:22 am
Majestic 1250 cabinet was in bad shape, the bottom section was loose and some veneer on the left and right shoulders were bad , the grill was loose and also the inside of cabinet was nasty to say the least. The lower center section, book match veneer was shot, the sides looks loke they used some cheap poplar veneer with no grain so om going to put on some nice walnut veneer to cover up the cheap poplar stuff. The left and right side vertical strips were also peeling off the veneer. I will replace with something close to as original as I can. I will put some mahogany crotch burl veneer on the left and right shoulders. I'm going to tone this cabinet that will make your eyes pop. Stay tuned for updates on this rare Majestic console. Speaker is ready and the chassis is going to be redone as well.
File comment: Rough shape
File comment: Not good, yuck.
File comment: Lightly Bead blast crap off inside cabinet
File comment: Bottom all re glued and cabinet sanded smooth. Ready for the veneers on sides , shoulders and center bottom.
 Post subject: Re: Majestic 1250 cabinet overhaul
PostPosted: Oct Sun 08, 2017 6:25 am
Speaker is ready
File comment: Nice 15 incher.
PostPosted: Oct Mon 09, 2017 4:31 am
OK I am coming along on the cabinet, got a lot done over the weekend. I am sharping my veneer skills and continuing to excel in it. Replacing veneer is an art form and has to be done right using the right tools and some patience an lots of practice. Anyway the cabinet now is ready for grain filler then I will apply my main color and color toning. THe shoulders I replaced the peeling veneer with walnut burl book match veneer, the front left and right vertical columns in zebra veneer along with factory lower base section , book matched like factory. Both sides were veneered in mahogany, the old stuff was a plain dull poplar veneer with no grain pattern like you see on the Midwest radio cabinets. The mahogany will be great macthing with the mahogany top section.
PostPosted: Oct Mon 09, 2017 8:41 am
As always looking beautiful Fred
Gary
PostPosted: Oct Mon 16, 2017 2:22 am
got some work done today on the cabinet, I didn't want to have to replace the veneer on the top section of cabinet but the veneer was bad, Something soaked into it over the years and I think it was an oil of some kind. The veneer would not sand properly and was very soft. So sparing no time I removed it and replaced with a book matched walnut and with maple strips. Everything will be stained and toned for the deferent woods to come together, should look wonderful with all new veneer. Mahogany on both sides, walnut burl on the upper side of the shoulders and walnut vertical columns, with zebra book match lower center section. Inside cabinet was painted dark blue as factory, also added 4 new metal floor guides to keep radio cabinet off the floor and easier to side on floor. Next week I hope to get the color on and get it sealed and perhaps get the clear coats applied. Chassis may be getting a new chrome job, its rusty and is in bad shape, so I may have to bite the bullet and get it re chromed. If you didn't notice I switched the zebra veneer I put on the vertical columns back to walnut, just didn't look right. also the top had sunk down a little and I had to fill and re level it , so now the top is perfectly flat again.
File comment: Veneer was soft and could not be saved, seemed like some type of oil got on the top, sanding it was impossible.
File comment: Removing veneer on top, it was bad. Could not sand it, the sand paper would clog up.
File comment: Straight edge shows how much the top had sunk down in the middle., would not look right even with new veneer.
File comment: After filling and block sanding I got it flat, so now the veneer will look flat, like it suppose too.
File comment: Nice edge joining the walnut and the maple.
File comment: Nice and tight, and flat.
File comment: Very nice grain pattern on the walnut. Should look outstanding when finished.
File comment: Escutcheon gives me a glimpse of what its going to look like.
File comment: Looking sweet.
File comment: Fresh dark blue paint, outer edge of rear cabinet goes color of cabinet. Not much left of label but saved what I could.
PostPosted: Oct Mon 16, 2017 8:43 am
Going to be a real handsome radio.
Look forward to the finished pics.
thanks Gary
PostPosted: Oct Thu 19, 2017 2:30 am
This radio is becoming a work of art, it think the way I toned it they would have sold more sets, I didn't want to make it look factory. The way I have now is stunning to say the least and I cant wait to finish this weekend. Right now I have only the sealer coats on . This weekend I will sand down the sealer with 320 grit and re clear with an %80 gloss with 5 coats of Mohawk clear and perhaps install the grill cloth. WOW what a looker.
File comment: New zebra book matched veneer
File comment: New book matched walnut burl upper shoulders both sides
File comment: New walnut top and face with new maple side strips
File comment: Black inner grill slats, and the upper base molding also in black
File comment: Upper shoulders , the ribbed sections and in extra dark walnut including the base moldings
File comment: This radio is taller than your average console
File comment: New lower walnut vertical strips, the fine detail is amazing on this cabinet
File comment: New walnut burl, the whole cabinet has been reveneered
PostPosted: Oct Thu 19, 2017 8:57 am
Boy! that is one beautiful radio (even my wife thinks so; that's high praise) and will stand out from the crowd. Back in the day it was made, possibly buyers liked a more austere finish or it faded and lost some beauty (like we have :D ; ).
A lot of work to strip the chassis and have it re-plated but worth it for such a wonderful result.
Is this one a keeper?
Did you level the top with Bondo Fred?
thanks for posting Gary
PostPosted: Oct Thu 19, 2017 12:12 pm
Yes I am planning on keeping this one, it such a nice looking radio. I bet it will sound amazing given the tube count and the 15 inch speaker. I did use a type of bondo to fill the low area on the top..
PostPosted: Oct Fri 20, 2017 3:24 am
Looks great!
PostPosted: Oct Sat 21, 2017 12:40 am
Outstanding!
I wanna be like you, Fred, when (if) I grow up :D
Mark
PostPosted: Oct Sun 22, 2017 3:53 am
Finished cabinet today, I'm very pleased with it and looking forward to getting the chassis complete and installed back into cabinet.
 Post subject: Re: Majestic 1250 cabinet overhaul (FINISHED)
PostPosted: Oct Wed 25, 2017 2:55 am
Looks great Fred.
Lenny
PostPosted: Nov Wed 01, 2017 1:49 pm
Chassis is all refurbished and I have to do now is recap and check everything, I went with black wrinkle finish instead of rechroming. I bead blasted chassis removing all the crap and old chrome. The finish turned out great, looks like factory did it even though the shields came wrinkle finish already. The cost would have been to much and the time .
PostPosted: Nov Wed 01, 2017 2:22 pm
Wow. I always love to see the beauty in the veneers and how they all come together. Thanks for the hard work you put in in saving this majestic radio.
PostPosted: Nov Wed 01, 2017 2:33 pm
Chassis turned out well; not original but worthy of the radio. Yes! having been there stripping and re-plating takes an lot of time.
What did you remove from the chassis to do the work?
Gary
PostPosted: Nov Wed 01, 2017 10:05 pm
Love it Fred....looks great.
Lenny
PostPosted: Nov Thu 02, 2017 12:47 am
Gary
I removed the tuning condenser and the complete dial assembly, I masked off everything else. I have seen chassis come in wrinkle finishes before, cant remember which they where. I almost puked when I got into the chassis, it was the nastiness chassis I ever pulled from a radio , I thought about getting a shot from the doctor to protect me from the crap that was on the poor chassis.
PostPosted: Nov Thu 02, 2017 1:44 am
Stunning, just stunning excellent work as always Fred.
Doug
***"Your best teacher is your last mistake"***
PostPosted: Nov Sat 25, 2017 2:30 am
Had some time to finish up the Majestic this Friday , day after Thanksgiving . The chassis had been gone thru and is now playing great. Found the correct speaker from Ed Jacobs that had one for sale on this forum. Right out of a model Majestic 1250 so now everything is original except for chassis paint and veneer on cabinet which unfortunately had to be replaced but by doing a decent job on cabinet it looks great and I can say this Majestic was saved from the bone yard and has many more years left on this planet.
File comment: Very clean looking, love those Push Pull 6l6 ,s.
File comment: Very Handsome radio
Post New Topic Post Reply  [ 28 posts ]  Moderator: Peter Go to page 1, 2  Next
Users browsing this forum: Scott and 14 guests
