It is currently Jan Sat 23, 2021 7:56 am
Post New Topic Post Reply  [ 46 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: zenith 12a58 restore
PostPosted: Sep Mon 03, 2018 8:48 am
Beautiful as always
Gary
PostPosted: Sep Thu 06, 2018 5:25 pm
Amazing work Fred!
-Jeremy
PostPosted: Sep Sun 23, 2018 5:10 pm
I have speakers all re done, small speaker coil rewound, both speaker cones , both transformers, repaint speaker frames and bell's , now maybe next weekend I can fire this old radio up. Dick is replacing the plate choke coil this week , I have two more electrolytic caps to replace also, then Dick will slowly power up and check everything, im sure there will be something not right, it always happens. Stay tuned.
File comment: New New New
PostPosted: Sep Mon 24, 2018 3:30 am
Wow - what an inspirational journey! Just awesome work! Thanks for sharing. That much work would take me months of work and wouldn't look anywhere near as nice.
If you're willing to share, I'd appreciate some additional details concerning rewinding speaker coils. This is something that I would not feel comfortable taking on until I learned more.
-Eric
Visit my DIY Home Theater page
http://www.facstaff.bucknell.edu/esanta ... ovies.html
PostPosted: Sep Tue 25, 2018 12:54 am
Thanks for the complements, the speaker field coil for the small speaker was rewound but I did not do that, I sent it out for that job.
PostPosted: Dec Sat 01, 2018 2:28 pm
Amazing work you do on these.
PostPosted: Apr Thu 18, 2019 1:48 am
Finally got my baby Strat finished and playing. This 12a58 looks great and the sound is just as nice. Lots of work went into this radio, cabinet and the chassis needed major repairs . These 12a58,s just aren't easy to come across and was well worth restoring . As you can see the chassis has a lot of news parts, just a whole lotta work.
PostPosted: Apr Thu 18, 2019 4:21 pm
Stunning, just stunning Fred!! I'm always just wowed by the quality and detail you put into your work.
One question about the chassis. I see the candohm resistor wasn't replaced. I've always replaced them with terminal strips and discrete resistors to avoid the possibility of a future chassis short or element going open. Am I just being paranoid?
-Nash
PostPosted: Apr Thu 18, 2019 11:06 pm
No, you are not. It is a high failure component and many here replace the whole thing also.
PostPosted: Apr Fri 19, 2019 1:39 am
Very Nice!
PostPosted: Apr Fri 19, 2019 12:38 pm
-Nash
I don't know why my electrical tech didn't recommend it be replaced, I do see one new big block resistor on that strip. I'm not an expert in that field. Mike did install an inline fuse where the power cord is soldered in. Also I had Mike add an input jack on the rear of chassis so one can play a CD player or anything else. One of my other guys Dick Morgan that works on my radios also only replaces those resistors only if there bad, I will have to ask those guys why they don't replace them if there,s a hazard to the safety of the radio . Thank,s for brining that to my attention and thank you for the complements on my refinishing and restore on the cabinet.
PostPosted: Apr Fri 19, 2019 6:26 pm
Beautiful work, Fred!
Bob
"The stupider it looks, the more important it probably is!" -- J.R. "Bob" Dobbs
PostPosted: May Sat 04, 2019 6:39 am
Hello Fred,
just amazing job the chassis paint job came looking great! Bet that radios sounds amazing .
I have a couple speakers that need to get re coned too then have to remember that place because they did nice job .
Sincerely Rich
PostPosted: May Sat 04, 2019 4:36 pm
What do you do with all the radios, is a money maker for you???
PostPosted: May Sat 04, 2019 5:34 pm
Amazing job, Fred!!! Probably the radio I long for the most, lol!
PostPosted: May Sat 04, 2019 5:56 pm
Fred does some for himself, and some for other people, hopefully at a reasonable profit. One deserves to be properly compensated for their work.
PostPosted: May Sat 04, 2019 6:42 pm
Absolutely.
PostPosted: May Tue 07, 2019 2:13 am
Absolutely LOVE your work Fred! I've been a fan for the last 5 yrs. I've kind of studied your technique thru your pictures and love it.
I do have a question though. You use Timbermate grain filler as I do now but I have found that some other stains are not accepted by the Timbermate filler like I would want them to be accepted. For instance, on restoring a 40-180 Philco and using Timbermate and then using Minwax Golden Oak wiping stain, the Minwax didn't get absorbed by the grain filler and I have white streaks in the wood. I'm wondering if you or anyone else has had this problem. I know you prefer Mohawk stain, which I love their toner but is their stain more compatible with Timbermate grain filler than Minwax stain and why? I do know one thing, I don't like the white streaks after staining and toning.
Any advice would be greatly appreciated.
Thank You
Dick
PostPosted: May Tue 07, 2019 2:38 am
Sorry I don't know why the timber mate will not absorb the minwax stain. I don't like that stuff like you said, the white streaks sounds like because the stain did not soak into the grain filler the grain filler remained white in the pores of the wood making that appearance, now unless you sealed the grain filler first then used the stain that would cause your problem also , grain filler has to be stained first and then you apply your clear sealer. Hope that helps you.
PostPosted: May Tue 07, 2019 6:13 am
No I didn't seal after the grain filling . I just sanded and then wipe stained with the Minwax stain. Yes, I don't understand why the white streaks won't accept the stain either. I just wanted to know if you had ever encountered this problem and if you have a fix for it.
So I think I might try a little more toner in those areas, although I'm afraid it might make it too dark. But it is always fixable. Thank you for responding Fred, I appreciate it.
Thanks Dick
Post New Topic Post Reply  [ 46 posts ]  Moderator: Peter Go to page Previous  1, 2, 3  Next
