It is currently Jul Fri 19, 2019 11:41 am
 Post subject: Gilfillan model 117x console restore
PostPosted: Dec Sat 29, 2018 4:10 pm
This unusual radio came to me to restore the cabinet, its from California and will be part of a WW2 museum collection. The front control panel book matched veneer will be replaced along with the top flat area. There are nail holes in the top, that veneer will be replace with new. Stay tuned for this makeover and perhaps the owner can chime in on this thread when the radio is placed in his WW2 museum.
 Post subject: Re: Gilifian model 117 console restore
PostPosted: Dec Sat 29, 2018 4:19 pm
Suprisingly Fred I had one of these awhile back... Bought it because of the chrome chassis... Did notice too that mine had exposed nail holes in the top as well... Maybe they held the veneer in place with tacks then removed once the glue dried??
PostPosted: Dec Sat 29, 2018 5:04 pm
If you sold it this maybe the same radio.
PostPosted: Dec Sat 29, 2018 5:18 pm
No, mine went to a local guy, here in South Dakota unless he moved to CA... I think mine was in a little better shape without the rings on the top and the veneer damage on the face... A really neat radio though.. I thought it was strange that they had those chambers on the sides where the cutouts are... Thought maybe set up for a higher end model with extra speakers? Also the chassis had component covers that had a neat Indian head on them that said "Inca"...
PostPosted: Dec Sun 30, 2018 2:53 am
I don't see any screws holding cabinet together but I do see many nails, maybe the top suppose to have been nailed down, I did notice filler were the nails are on other parts of radio. I worked 8 hours today on radio and came a long way, ready for refinishing soon. Lot of work, replacing veneer takes some time and all the other stuff does to. sure will look nice when finished, the customer will have to post pictures of it when radio is in it and completed, all im doing is cabinet.
File comment: Cabinet stripped and the lower base removed
File comment: Lower base stripped.
File comment: Lower base primed, this section will be painted black. Primer will make for very smooth finish.
File comment: Front panel sitting on top of new veneer for tracing out pattern
File comment: Making Templet for new veneer
File comment: Templet being used for new veneer cutout,
File comment: Heat lock veneer glue being applied
File comment: Rolling out glue to a nice thin even coat, this is done on both surfaces being glued
File comment: Heating up glue to speed things up abit, dries quicker. You have to let both surfaces dry first before putting together and ironing.
File comment: nice pattern here, book matched mahogany veneer.
PostPosted: Dec Sun 30, 2018 3:07 am
Lets keep going
File comment: Glue applied on both pieces being glued together
File comment: When you position your veneer your ready to use an iron, heat will reactivate the glue and bond both surfaces together.
File comment: Nice and easy now!
File comment: That's Me!
File comment: Finished control panel
File comment: New mahogany top surface
File comment: Lightly sanded and ready for grain filler
File comment: Grain filler applied
PostPosted: Dec Sun 30, 2018 3:14 am
Beauty, Fred!! What a nice treat to find this thread. I wasn’t expecting you to be this far along already. I can’t wait to get it back!!
PostPosted: Dec Sun 30, 2018 3:20 am
Fred,
Thanks for taking the time to show us your techniques.
Robert
PostPosted: Dec Mon 31, 2018 1:00 am
Ok worked all day getting this wrapped up except for the inside of cabinet. Really turned out nice, good lookin Radio. I'm off this Tuesday as most of us are so I figured id work over the weekend. Happy new year soon.
File comment: Primed the base for a very smooth fish, it was pretty ruff.
File comment: Using a veneer saw cleans the tiny gap out in between the wood pieces like factory
File comment: Painted sperate from radio cabinet
File comment: Installed base , this was nailed and glued from factory. I'm going to add steel L brackets for better hold.
File comment: Painting upper corners black like factory
File comment: Most of cabinet is put together now and starting to spray the sealer coats on, stain and toners were already done
File comment: Nice nice nice
PostPosted: Dec Mon 31, 2018 1:10 am
Few more pictures, let it sink in a little.
File comment: Refinished knobs!
File comment: Look at that, I want one of those.
PostPosted: Dec Mon 31, 2018 2:07 am
SPECTACULAR Fred! Thank you for posting all the pics of the progression.
 Post subject: Re: Gililfian model 117x console restore
PostPosted: Dec Mon 31, 2018 10:42 pm
Beautiful, Fred!!! Can't wait to get it back and get the guts back in it!!
PostPosted: Jan Wed 02, 2019 3:33 am
WOW!
PostPosted: Jan Wed 02, 2019 5:55 am
For the sake of clarification, in case future enthusiasts look for this model, the radio is an 11 tube 1936 Gilfillan model 117x with a chrome chassis and tuning eye. It also has a jewel in the front panel that lights up indicating the set is on.
This cabinet is built like a battleship with 3/4” plywood used in much of it! There are clarifier boxes on either side of the cabinet where the slots are. No doubt, to help spread the sound from its large speaker.
 Post subject: Re: Gilfillan model 117x console restore
PostPosted: Jan Sun 06, 2019 10:14 pm
Ok the Gilfillan is complete now, looks very nice. This radio will display nicely in the WW2 museum. I will let dry for a week or so and wrap and box it back up send it back VIA Greyhound to sunny California.
File comment: Philco lid refinished will go back with Gilfillan cabinet.
PostPosted: Jan Sun 06, 2019 10:43 pm
Where is the WWII museum?
PostPosted: Jan Sun 06, 2019 11:27 pm
The owner said he would post pictures of the museum here on this post, its in California. Maybe he can do it before he gets the radio back.
Post New Topic Post Reply  [ 17 posts ]  Moderator: Peter
