It is currently Feb Mon 17, 2020 8:26 am
 Post subject: Philco 90 decals??!! how to remove or should I leave it
PostPosted: May Mon 06, 2019 7:22 pm
Hello, I have had this radio since 2004 and so hate the decals on it. Is it possable to remove the decals under the coating or will it require a ton of work. Sand it a bit, and re apply whatever coating is on it? Yes, I just noticed that the cabinet is not a 90 but a 70....things I didnt notice until years later :lol: The chassis is a canadian model 90 with 1 47 output tube.
 Post subject: Re: Philco 90 decals??!! how to remove or should I leave it
PostPosted: May Tue 07, 2019 2:43 am
That philco decal is suppose to be there but not the others, You can not remove it without damage to the clear coat finish, the decal maybe under the clear, if its not under the clear you can remove it with water and your finger. I do see the out line on borders of decals and is probably not under the clear.
PostPosted: May Tue 07, 2019 5:33 pm
I have never seen a 90 with decals on it. Going to apply water and see if the knob decals come off. I didnt feel anything when I ran my fingernail across the decals.
PostPosted: May Wed 08, 2019 1:36 am
You are correct, the Philco 90 had no decals
Steve
M R Radios C M Tubes
PostPosted: May Wed 08, 2019 2:27 am
So sorry I screwed up , I will never respond to any of these post,s till I wake up and dump a bunch of coffee down in me. No decals on that radio is correct, philco name already on escutcheon. :roll: :roll:
PostPosted: May Wed 08, 2019 12:10 pm
I wet a wash rag with hot water. rubbed on the philco decal. It didnt affect it at all. When I run my fingernail over the decal I feel nothing catch
PostPosted: May Wed 08, 2019 12:52 pm
Well very possible the decals are buried into the clear in that case you will have to strip least the front panel very carefully and refinish after the decals are removed.
PostPosted: May Wed 08, 2019 4:41 pm
so stripping just the decal areas and reapply what ever coating afterwards would look like donkey butt or would that work, or is that strip the whole front panel.
PostPosted: May Thu 09, 2019 1:55 am
You should strip the entire front panel and refinish. Don't try and strip just the decal area it will look like dodo.
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter
