It is currently Feb Fri 21, 2020 6:16 am
 Post subject: Mohawk lacquer toner
PostPosted: May Mon 13, 2019 8:14 pm
Do you need to put a finish on it after using the lacquer toner ? I do you have pre-cat satin and semi gloss ? Sansui 7070 wood case.
 Post subject: Re: Mohawk lacquer toner
PostPosted: May Mon 13, 2019 10:00 pm
You don't have to, but it generally looks better if you clear the whole cabinet after it is toned. Pre-cat is great stuff.
PostPosted: May Mon 13, 2019 10:42 pm
The toner is a gloss finish, so you need to spray it with clear if you are using a clear which is not a gloss finish.
PostPosted: May Tue 14, 2019 12:28 am
thanks guys, I think the 70's stereo stuff will look good with the satin
