It is currently Feb Fri 21, 2020 7:52 am
 Post subject: Substrate repair.
PostPosted: May Tue 14, 2019 11:32 am
I am working on the tombstone with a broken substrate around the waterfall area (1 1/4" radius). The portion of it has been already removed and the new piece is ready to be glued in. The material is 1 mm walnut 2ply veneer. When going around the radius from the top down, which side of veneer should be on the outside the curve -with a grain, going vertically, or horizontally, across the grain ? Thanks.
Post New Topic Post Reply  [ 1 post ]  Moderator: Peter
