It is currently Dec Wed 11, 2019 1:10 am
 Post subject: Pioneer RT-707 R2R Bottom Plate Rust Removal (Pictured)
PostPosted: Jun Thu 06, 2019 9:27 pm
I have a Pioneer RT-707 Reel to Reel that has a bottom plate that sat on a wet carpet for a while and now has rust on it (pictured below). The rust does not go completely through the plate (pictured below) and the interior electronics appears to have been spared.
I had to spray Radio Shack Contact Cleaner and Lubricant to the screw heads and then use vice grips to loosen them and then a screw driver to remove them.
Any ideas on how or what to use to remove the rust?
Bottom:
Plate Outside:
Plate Inside:
TIA,
Terry
 Post subject: Re: Pioneer RT-707 R2R Bottom Plate Rust Removal (Pictured)
PostPosted: Jun Thu 06, 2019 10:07 pm
KRUD KUTTER.
Jim
KE8GMW
"AC volts and DC volts and little lamps and lities..."
PostPosted: Jun Thu 06, 2019 10:18 pm
A couple of methods come to mind another rust remover is naval Jelly
or soak in a vinegar salt solution.
However I would get a electric drill and use a wire wheel. also used a very rough sandpaper. ( I have used this in the drawers of a big VIDMAR Parts Cabinet. Som of the bottom drawers were almost as bad as your problem. I was surprised how fast it was compared to chemicals.)
Visit our site:
I was smokinradios Long time ago (2004)
PostPosted: Jun Fri 07, 2019 2:25 am
Thanks, I have enough information now to get started...
Users browsing this forum: Brett_Buck and 2 guests
