It is currently Dec Thu 02, 2021 5:17 pm
 Post subject: Gilfillan 1131-C Resto start :stripping:
PostPosted: Aug Sat 15, 2015 3:15 am
This is the next candidate for the finish removal.Some of the front areas are solid Walnut so this will
be a new challenge for me as I have been used to working strictly w/ veneers.Should be an easy wash
off with the 50/50 mix of lac thinner and acetone.Will show pics as I progress. Here are the before shots.
There is no saving the original to far gone.Crazed to the max.
Doug
***"Your best teacher is your last mistake"***
 Post subject: Re: Gilfillan 1131-C Resto start
PostPosted: Aug Thu 20, 2015 1:57 am
Wow, that's nice! I have a gillafin bros. Cabinet that I finished it has the same brass dial and magic eye bezels. I wonder if the dials are the same as well?
 Post subject: Re: Gilfillan 1131-C Resto start :stripping:
PostPosted: Sep Mon 07, 2015 2:58 am
Cabinet stripped except the black which is stiff nylon brush time and 50/50 mix.
Doug
PostPosted: Sep Mon 07, 2015 3:04 am
Site Admin
If you're redoing the black trim black, there isn't any reason to have to remove the color 100%.
PostPosted: Sep Mon 07, 2015 2:44 pm
Hi Alan,
Don't you think the areas that are badly chipped and flaked will show thru the new paint,or do
you think it will blend.
Doug
PostPosted: Sep Mon 07, 2015 5:13 pm
Site Admin
If it feels smooth, it's good enough.
PostPosted: Jul Tue 02, 2019 9:00 pm
So Doug,
How did it turn out?
No pics for @ 4 years?
C'mon, I wanna see it!
Brett
Post New Topic Post Reply  [ 7 posts ]  Moderator: Peter
