It is currently Jul Tue 07, 2020 4:14 am
 Post subject: Zenith decals- above or below the laquer?
PostPosted: Nov Thu 07, 2019 9:09 pm
I am having the cabinet refinished on my Zenith 7-S-363- should the band decals go on before or after the cabinet is resprayed? Thanks Jackson
 Post subject: Re: Zenith decals- above or below the laquer?
PostPosted: Nov Thu 07, 2019 9:12 pm
Normally you would apply your decals just before the last coat of lacquer. I do about 3 coats total, so after the first 2 coats apply decals, then spray the final coat.
Tony
PostPosted: Nov Thu 07, 2019 11:05 pm
I’ve only done a few, but I go 1 coat of lacquer. Hit it with 300 paper. Decal. Then 2 coats on top. I’ve found the decals move around easier with 1 coat under. I think we will all agree the decal can go on at anytime, but at least 1 coat on top to protect it.
Freeman
PostPosted: Nov Fri 08, 2019 9:56 am
I always spray mist coats over the decal at first: some break up if the coat is too heavy. If you have spares try a couple on a piece of scrap.
Also make sure to give the decals time to dry out.
Gary
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter
Users browsing this forum: wireless 12 and 11 guests
