It is currently Jul Tue 07, 2020 3:52 am
 Post subject: Philco 42-1008 refinish
PostPosted: Sep Fri 06, 2019 2:14 am
For you philco fans this common set which I believe was the last batch of consoles that philco made before starting its war production in 1942 or there abouts. Its in the shop for a total redo including some veneer replacement on the top of both shoulders. Water damage caused the veneer to lift and turn black probably from a plant. The chassis and turntable are going thru a restoration as well, when finished this old timer will be sitting tall once again in the family's home.
File comment: New veneer on left and right sides
File comment: Grill with slats removed
File comment: Starting to apply grain filler.
 Post subject: Re: Philco 42-1008 refinish
PostPosted: Sep Tue 10, 2019 3:44 am
Hello Fred
nice
PostPosted: Sep Wed 11, 2019 1:42 am
Hello Radiorich, Philco coming right along, waiting on reproduction grill cloth and decals for wooden escutcheon which will be refinished as well. I will post more pics when radio cabinet is done. Turntable metal frame was rusty so I bead blasted and painted for good measure.
PostPosted: Sep Fri 13, 2019 3:14 am
Finished up this common Philco, I must say its the nicest one I've seen so far, not because I finished it but because this model looks drab from factory. I did a little of my own touch's to make the cabinet more appealing. Looks pretty good for a run of the mill cabinet.
PostPosted: Sep Fri 13, 2019 4:34 am
Hello Fred,
looking very nice and the turntable frame looks good .
Sincerely Rich
PostPosted: Sep Fri 13, 2019 1:02 pm
Hi Fred,
Your Philco came out great! I know that veneer work is not as easy as it looks. What did you use for grain filler?
PostPosted: Sep Fri 13, 2019 3:14 pm
That is one gorgeous looking cabinet!
I’d love to see it in person.
If I had a radio that looked like that, my wife would let me keep it in our living room.
-EB
PostPosted: Sep Fri 13, 2019 4:47 pm
Franzis wrote:
Hi Fred,
Timbermate is the grain filler. You can order on amazon.
PostPosted: Sep Fri 20, 2019 12:58 am
Fred, can you give a radio cabinet restoration class, I'll fly out of Pennsylvania for the first class! Your work is awesome! Nice job again!
PostPosted: Sep Sun 29, 2019 6:34 am
Fred...
If your sticker is bad on your 23X I made new ones,
Kirk
PostPosted: Sep Sun 29, 2019 1:41 pm
So nice of you to ask, I will look and see if it needs replacement, thanks.
PostPosted: Sep Sun 29, 2019 2:18 pm
Don't use that one though.. I just saw that I spelled Aerial wrong. Luckily I still have the PDF file.
PostPosted: Sep Sun 29, 2019 7:35 pm
Fred, you always forget to people that your number one ingredient is hard work. The trick is avoiding unnecessary hard work. Looks great!
KK6IYM
PostPosted: Sep Sun 29, 2019 7:36 pm
Hello Kirk ,
you did beautiful job on the new label design
PostPosted: Sep Sun 29, 2019 8:03 pm
radiorich wrote:
Hello Kirk ,
Thanks Rich,
I need to print it and then age it a little.. I wish the numbers and letters weren't so crisp...
PostPosted: Sep Mon 30, 2019 6:15 pm
The font also doesn't match on some letters....
PostPosted: Sep Mon 30, 2019 9:04 pm
Yup, The wide U and the offset Y could not be matched.
You are welcome spend 11 hours making one with the right fonts.
PostPosted: Oct Tue 01, 2019 3:02 pm
Here is a quick 15 minute touchup of the original. I wanted something to better match my aged Philco 91 console radio. I forgot that I needed it until I saw your pic. Sorry for the compressed jpg but I was too lazy to host the pic elsewhere and link to it.
PostPosted: Oct Tue 01, 2019 7:54 pm
Beautiful wood-working skills. I love it when the tone is just right like that. Warm and rich looking.
PostPosted: Jun Thu 04, 2020 3:22 am
Fred, sorry to jump back in time to this Philco but it's a cabinet that I'm starting on now. Was the escutcheon glued in? If so did you use heat to remove? Also, is that new Vvivid brand vinyl faux coating?
Post New Topic Post Reply  [ 25 posts ]  Moderator: Peter Go to page 1, 2  Next
Users browsing this forum: Gasman and 6 guests
